There is a small black circular object @ 25mm deep and @ 75mm diameter to the rear of the inlet manifold and connects to the top of the cam cover. When I spray "Bradex" over it , the revs pick up and seems to calm the lumpy idle and when the engine is switched off, it seems to "hiss" for a few seconds.
Am I correct in thinking its an oil trap and can I replace the item ?
Cheers, Mart.
