I'm such a chicken! Jackpoints...
Wega
Post Tue Aug 26, 2014 11:42 am
I just need to be 100% sure that this is a correct place to put jack stands:
It's ok, you can laugh at me, but I really dont want to ruin my new E30, and I have never jacked up an E30 myself. :mad:
BenHar
Post Tue Aug 26, 2014 1:32 pm
Post Tue Aug 26, 2014 1:34 pm
Jack stands where you have them puts a lot of strain on the rear beam bushes, BUT no more than a correctly fitted bush in good condition should be able to take. A better (but less safe) place to put them is under the large nuts securing the rear beam, just outside of where the stands are in your pic.
Wega
Post Tue Aug 26, 2014 2:18 pm
Thanks guys, I just needed to be sure.
Went all in to make sure I would be ok if something went wrong:
Brian: You mean this point, right?
Rich320I
Post Tue Aug 26, 2014 3:07 pm
yes, iv jacked mine from that point many times
G-Bear
Post Tue Aug 26, 2014 3:31 pm
Nothing to be worried about asking, everyone has to start somewhere, I had the same worries when I first started tinkering with cars... I used to jack my car up through gritted teeth...
**BANNED**
Post Tue Aug 26, 2014 6:40 pm
Another option is to make up a few packing pieces from plywood and use the rear cill jacking point for your stands.
Youth is wasted on the young.
Wega
Post Tue Aug 26, 2014 6:51 pm
Thanks for all you comments, it all went fine and now I know how to do it next time. But it really isnt comfy lying under the car and working, I envy those with a lift :)
maxfield
Post Tue Aug 26, 2014 9:09 pm
Post Tue Aug 26, 2014 9:18 pm
daimlerman wrote:Another option is to make up a few packing pieces from plywood and use the rear cill jacking point for your stands.
That's what I have, and do, to raise the car with a jack, but you can't put stands in the same place as the jack!
**BANNED**
Post Tue Aug 26, 2014 9:41 pm
I raise the car using either 'drive on' ramps or jack under the diff or the beam bush mounts to get the thing high enough to support by the cills.
I guess that it's personal choice just how you get the car high enough to work under in reasonable comfort.
Even my new 'man-cave' that is currently at foundation level will not be high enough to allow a 2 post lift! :cry:
