Heater matrix leak ?
eddypeck
Post Tue Aug 19, 2014 1:53 pm
Whilst giving the new purchase a good overall check I found this staining on the plastic in the passenger footwell. Would this indicate a previous/current heater matrix leak? or something else.
ross_jsy
Post Tue Aug 19, 2014 2:04 pm
Was the car previously owned by a zoner called Pony by any chance? :)
steve_k
Post Tue Aug 19, 2014 3:05 pm
Looks like it could be a leak, if it is then its either the O rings for the valve or the matrix it self.
trojen
Post Tue Aug 19, 2014 3:18 pm
steve_k wrote:Looks like it could be a leak, if it is then its either the O rings for the valve or the matrix it self.
This i had the same issue, 9 times out of 10 its the heater valve. should be a simple swap out job.
318is
316i Touring
eddypeck
Post Tue Aug 19, 2014 3:35 pm
How can I tell if it's been done already and just left staining or if it's still leaking? Only got the car on the weekend, previous owner before the guy I got it off of was on here GC318.
zaust
Zone day release
Post Tue Aug 19, 2014 3:37 pm
damp carpet and coolant loss.
M30 Tech 1 Touring on gas.
eddypeck
Post Tue Aug 19, 2014 4:02 pm
Coolant was low, would it leak at all times or only with heater on hot? any how to's on the above mentioned valve fix?
Currently have all the seats out for a deep clean, so plenty of space to work in. May as well do it before they go back in.
Also there's a small crack in the dash so if that has to come out may as well replace that now too if I can find one.
BenHar
Post Tue Aug 19, 2014 4:42 pm
Post Tue Aug 19, 2014 6:29 pm
You can see the valve if you first take off the inspection panel above the glove box, then the one to the right, or, since the car is partly stripped remove the rear centre console, followed by the front console, and you'll be able to get at the relevant parts, as well as clean the carpet properly, and recover the glove box torch that is probably under there.
trojen
Post Tue Aug 19, 2014 6:45 pm
Brianmoooore wrote:You can see the valve if you first take off the inspection panel above the glove box, then the one to the right, or, since the car is partly stripped remove the rear centre console, followed by the front console, and you'll be able to get at the relevant parts, as well as clean the carpet properly, and recover the glove box torch that is probably under there.
Ha this made my day when i found mine, thought i was a lucky one. It didn't work though.
318is
316i Touring
Post Tue Aug 19, 2014 7:34 pm
trojen wrote:
Brianmoooore wrote:You can recover the glove box torch that is probably under there.
The cases are glued together, but the glued joint can be carefully prised apart, the batteries replaced and a LED upgrade performed if you so desire.
minesapint
Post Wed Aug 20, 2014 10:08 pm
Do you know what type, ref number & where to obtain, these batteries?
Can no longer get my white E30 type torch new from BMW.
Post Wed Aug 20, 2014 10:51 pm
Sorry, haven't done one lately, or have an old one to hand, but they came from CPC-Farnel the last time I rebuilt a batch. Measure up the old ones and look through their catalogue.
minesapint
Post Thu Aug 21, 2014 12:54 am
Brianmoooore wrote:Sorry, haven't done one lately, or have an old one to hand, but they came from CPC-Farnel the last time I rebuilt a batch. Measure up the old ones and look through their catalogue.
Found this.......... http://www.meeknet.co.uk/e32/Torch/Index.htm
minesapint
Post Fri Aug 22, 2014 5:42 pm
If anyone does follow this guide for replacing batteries, note: the batteries suggested are too thick to fit. The batteries which do fit are Varta V250H, (these are also the original ones in my torch), follow link to CPC Farnell, (thanks Brian) £2.22 each.
http://cpc.farnell.com/varta/5562520106 ... dp/BT03144
Post Fri Aug 22, 2014 6:38 pm
:thumb:
eddypeck
Post Mon Aug 25, 2014 12:54 am
Back on topic, found the culprit
Read the guide, Don't think I'll mess around trying to fix it think I'll just fit a new one. That is unless I find out they're stupid money?
Also, I have the torch. It was in its place in the glove box but obviously not working. I'll have a go at the fix one day. Thanks for the links.
Post Mon Aug 25, 2014 9:41 am
Don't forget to check that your coolant pressure cap has been replaced under the safety recall.
eddypeck
Post Mon Aug 25, 2014 1:04 pm
Brianmoooore wrote:Don't forget to check that your coolant pressure cap has been replaced under the safety recall.
There was a spare cap in the boot, how can I tell? is there a part number reference or something?
Post Mon Aug 25, 2014 1:30 pm
Most of the replacement caps have a yellow disc at the bottom. A BMW dealer can tell you if a replacement has been issued for your car from the VIN (and change it if it hasn't), but of course, the replacement might not still be on the car.
Only applies to 1.4 bar caps, BTW, so excludes the iS.
eddypeck
Post Mon Aug 25, 2014 8:07 pm
Anyone know the part number or where to get the valve? Or is it a bmw only part?
Post Mon Aug 25, 2014 10:24 pm
Part # is 64 11 1 386 706 for non aircon cars, and the last price I have is around £100, but there have been serious price rises lately. Plenty of good second hand ones around.
eddypeck
Post Tue Aug 26, 2014 12:09 am
eeek! thanks, :( can they be fixed?
SHAKEELE30
Boost Junkie
Post Wed Aug 27, 2014 7:06 pm
i think it was £140-160 for a new one... best bet is get a decent 2nd hand one, should be around £30-40...and no they cant be fixed
