Put m20b25 lump out of a H reg into a G reg 1.6 .
Car turns over fine, fuel is flowing, there is spark. But no fire.
Not even a splutter
Have had engine in bits while was out, mainly cleaning it, timing belt, water pump all been changed, blue and brown temp sensors replaced, gasket, etc replaced.
Only thing is I had a fully charged booster pack on the positive and negative terminals. Is this enough or should I have a battery connected too?
Fuel pipe that had fuel flowing out from when cranking, does this go on the bottom of fuel rail or directly into fuel reg?
