Mapping of M52
Hopchop
Went up on the rolling road at Gaydon on yesterday, got a horrible read out and below standard read out for bhp-181.
This was very disappointing considering my car is fitted with a full Stainless Vortex system, obviously all the usual mods M50 manifold etc. On the plus side the exhaust sounded excellent.
The graph also showed that my cars fueling is all over the place, I think a remap is needed and hopefully this is the reason that the power figure is so bad!
Anyone know a trusted company that have mapped m52's before preferably in and around London including home counties.
Quaser
you sure you havent got the 323i engine??
Hopchop
Actually scrap that mine is single Vanos not a TUQuaser wrote:you sure you havent got the 323i engine??
maf260
Was the reading at the wheels or flywheel?
Hopchop
Flywheelmaf260 wrote:Was the reading at the wheels or flywheel?
pnd
bw chip tune is where I would take it.
HairyScreech
You would only need a remap if the ecu is not the right one for the car.
Otherwise I would be checking all your sensors.
Quaser
bw chiptune is where i would NOT take it!
Do you have an M52 loom and ECU? Or is it a half M50 lash up?
Hopchop
DanThe wrote:Do you have an M52 loom and ECU? Or is it a half M50 lash up?
Below is what I have been told is in the car
-Remapped OE OBD1 E36 ECU
-Modified OE wiring loom to suit E30 installation
Quaser
have you got a pic? i thought m50's were odb1 and m52 odb2
Ignore the OBD nonsense. If its a Bosch ECU it will be from an M50, if its a Siemens ECU it will be M52
The M52 stuff is what you want to run your engine properly, I wouldnt for one minute believe that your ECU has been remapped if its only putting out 181hp
Are you 100% sure that it is a 2.8 engine?
Check the type number on a flat surface down near the LH engine mount arm. A 2.8 should start 28.DanThe wrote: Are you 100% sure that it is a 2.8 engine?
Hopchop
Cheers Dan I'll have a lookDanThe wrote:Ignore the OBD nonsense. If its a Bosch ECU it will be from an M50, if its a Siemens ECU it will be M52
Hopchop
Cheers Brian I'll check that also!Brianmoooore wrote:Check the type number on a flat surface down near the LH engine mount arm. A 2.8 should start 28.DanThe wrote: Are you 100% sure that it is a 2.8 engine?
pnd
why? I have driven some cars mapped there and they went very well especially compared to other maps.Quaser wrote:bw chiptune is where i would NOT take it!
LondonTom
Also keen to hear what is wrong with them - seen some good reviews on other sites.pnd wrote:why? I have driven some cars mapped there and they went very well especially compared to other maps.Quaser wrote:bw chiptune is where i would NOT take it!
rich318i
I was told they are good. Like to see some of their work though
LondonTom
Have you finished building your engine yet?rich318i wrote:I was told they are good. Like to see some of their work though
rich318i
Not even started it yet it should be at the stage of putting in the car by now but other commitments have been in the way
Once its done i'll be going to see them
HairyScreech
It should only take a picture of the shape of the inside of the maf sensor plug to say what ECU it is. The Siemens and the Bosch are different, that and a M50 uses a hot wire and the M50TU uses a hot film.
Thus: M50 = Bosch + Hot wire Maf
M50TU = Bosch + Hot Film Maf
M52 = Siemens + single vanos
M52TU = Siemens + double vanos.
Provided the right loom has been used with the right ECU! For which there is no guarantee, but it would at least identify the loom.
Hopchop
I checked the ECU and it's a siemens and I definitely have single vanos. I changed the air mass meter and think I have found the problem, now just need to go back on the rollers, someone suggested bw tune but someone says they are crap, I don't know where to go!!HairyScreech wrote:It should only take a picture of the shape of the inside of the maf sensor plug to say what ECU it is. The Siemens and the Bosch are different, that and a M50 uses a hot wire and the M50TU uses a hot film.
HairyScreech
In which case you should have EWS as well (or at lease an ews delete chip)
The MAF sensors for the later cars are sort of interchangeable, as in they all fit the plug but don't all give the same readings, VERY worthwhile making sure you have the right MAF for the ECU/Tune.
mcjjordan
How can you tell?
Are there part numbers on them?
Www.jvsautoelectrical.co.uk
Alarms,immobilisers,trackers,locking,windows,rewires,fire damaged,mobile service in hampshire.
