Flat spot when setting off
skidlidsid
Im getting a big flat spot when i set of from standing and every time i go back on the throttle.
It ticks over fine, and goes ok the rest of the time, it does it hot or cold, i've changed the plugs/leads/dizzy cap/rotor arm, and cant see any air leaks.
Anyone got any ideas?
Cheers Sid
Cheers Sid
1990 320i Auto Sterling Silver
Jon_Bmw
- Dangerous when thinking
TPS possibly, i should click just as you open the butterfly on the TB.
skidlidsid
Just tried that can't hear a click, is it suposed to click at the first bit of throttle?
Wid77
Yes, i think it is meant to click as soon as you open the throttle.
Jon_Bmw
Hmm they are a bit of a pain to adjust in situe as the adjusting bolts on the bottom of the TPS are hampered by the inlet manifold. Just take the throttle body off and do it that way, but use a new gasket.skidlidsid wrote:Just tried that can't hear a click, is it suposed to click at the first bit of throttle?
You could cheat and lower the idle by twisting out the screw that controls where the butterfly closes to, perhaps try that and see if it gets rid of the hesitation, you want to be hearing that click with the slightest movement of the butterfly.
skidlidsid
Got it adjusted now it clicks when you press throttle, but still same flat spot.
Turbo-Brown
- Boost Junkie
Wouldn't be the idle air control valve would it?
Mabey if it's a bit gummed up it might not be reacting as quickly as it should?
Jon_Bmw
Yes that would be my next port of call, then try looking for air leaks with carb cleaner or the like.Turbo-Brown wrote:Wouldn't be the idle air control valve would it?
skidlidsid
Where is that situated at cant seem to find it in the manualTurbo-Brown wrote:Wouldn't be the idle air control valve would it?
Is another name for it "idle air stabiliser valve"?
Jon_Bmw
Yes thats the one. On this pic, hope you don't mind glen, its near the top of the picture directly above the dip stick tube. It'll have a plug on the end so check that isn't fouled up. It has 2 pipes going on the throttle body.
skidlidsid
Right i'll have a go at that in the morning
Whats the best way carb cleaner or petrol?
Wid77
I think carb cleaner is usually recommended. I would be interested to find out how you get on as i have exactly the same problem with my '88 325i touring. Cheers.skidlidsid wrote:Right i'll have a go at that in the morning
skidlidsid
I will post up my findings when i've got it back together.Wid77 wrote:I think carb cleaner is usually recommended. I would be interested to find out how you get on as i have exactly the same problem with my '88 325i touring. Cheers.skidlidsid wrote:Right i'll have a go at that in the morning
DON'T TOUCH THIS SCREW!Jon_Bmw wrote: You could cheat and lower the idle by twisting out the screw that controls where the butterfly closes to, perhaps try that and see if it gets rid of the hesitation, you want to be hearing that click with the slightest movement of the butterfly.
skidlidsid
Got the idle air control valve of this morning, and noticed the big rubber intake hose that it goes into has got a small split underneath where it fits onto the airflow meter.
So i'll get one on order, i think i'm getting there now.
skidlidsid
Update
In the end i fitted a new hose from the airflow meter to the throttle body, new hose from the idle control valve to the throttle body, and cleaned the idle control valve.
All sorted now flat spot gone tickover even better now.
Anyone else has similar problems check them 2 hoses they are only Ԛ£16.81 for the pair(well worth it).
Jon_Bmw
What are the exact implications of "touching" this screw? I could learn something here i think.Brianmoooore wrote:DON'T TOUCH THIS SCREW!Jon_Bmw wrote: You could cheat and lower the idle by twisting out the screw that controls where the butterfly closes to, perhaps try that and see if it gets rid of the hesitation, you want to be hearing that click with the slightest movement of the butterfly.
It's only got one correct position, and BMW set it there.Jon_Bmw wrote:What are the exact implications of "touching" this screw? I could learn something here i think.Brianmoooore wrote:DON'T TOUCH THIS SCREW!Jon_Bmw wrote: You could cheat and lower the idle by twisting out the screw that controls where the butterfly closes to, perhaps try that and see if it gets rid of the hesitation, you want to be hearing that click with the slightest movement of the butterfly.
Moving it messes up the TPS and idle control function, so introducing more faults to mask the true faults.
