engine cut out now wont start no fuel no spark
h2ggv
driving in my 325i sport yesterday and it just cut out.
Thought it was the fuel pump as it wasn't pumping linked relay out and it pumps take link off no pump noise or pumping of fuel.
I have tested the relays and all are ok
Also the car is not sparking any ideas anyone
Thanks in advance cheers
HairyScreech
All fuses intact? I know there is at least one for the DME.
Crank sensor ok?
Crank sensor ok?
Grrrmachine
- E30 Zone Wiki / Team Member
It's either the DME relay or the CPS. Try bridging the DME relay just like you did for the fuel relay, and if that doesn't start the car then get a replacement CPS on order.
h2ggv
tried the dme bridge still no joy crank sensor is brand new changed about 2 weeks ago
h2ggv
Tried most of that still cant get it to go getting power to coil car cranking just no spark.Speedtouch wrote:http://www.e30zone.net/e30zonewiki/inde ... oubleshoot
no fuel pumping no spark
Sounds like a duff coil then, or bad engine to body earth strap, maybe...
h2ggv
was thinking coil but why would that cause the pump not to work strange how the 2 things aint workingSpeedtouch wrote:Sounds like a duff coil then, or bad engine to body earth strap, maybe...
Grrrmachine
Just because you fitted a new CPS doesn't mean it hasn't failed already. In all likelihood you've been sent a duff part, or bought a cheap one to start with.
Other option is that you fitted it incorrectly and the fan belt has rubbed through the wire, or you didn't plug it in tight enough and it's worked itself loose.
Disconnect it and confirm that you get a reading of about 540 ohms across the pins.
h2ggv
thanks will have a look at the cps in a hour or so would that cause the fuel pump not to run?Grrrmachine wrote:Just because you fitted a new CPS doesn't mean it hasn't failed already. In all likelihood you've been sent a duff part, or bought a cheap one to start with.
Check that the water pump pulley hasn't destroyed the lead from your new CPS. Yours wouldn't be the first to only last a few hours because it hadn't been fitted properly behind the pulley.
There are NO fuses in any feed to the engine/DME, unless you count the one that is fitted next to the battery only on cars with the battery in the rear.
h2ggv
checked fuse off the rear battery thats fine.Brianmoooore wrote:Check that the water pump pulley hasn't destroyed the lead from your new CPS. Yours wouldn't be the first to only last a few hours because it hadn't been fitted properly behind the pulley.
if the cps has been damaged would it cut out the fuel pump?
h2ggv
disconnected it pulled out traced wire no damaged on the cps checked reading in ohms accorss all 3 pins and getting a open circuit no reading at all on any of the pins its 3 weeks old.Grrrmachine wrote:Just because you fitted a new CPS doesn't mean it hasn't failed already. In all likelihood you've been sent a duff part, or bought a cheap one to start with.
would this cause the fuel pump not to run?
Grrrmachine
h2ggv wrote:would that cause the fuel pump not to run?
h2ggv wrote:if the cps has been damaged would it cut out the fuel pump?
YES!h2ggv wrote:would this cause the fuel pump not to run?
h2ggv
so getting no reading on the the cps open circuit is that at fault its brand new tooGrrrmachine wrote:h2ggv wrote:would that cause the fuel pump not to run?h2ggv wrote:if the cps has been damaged would it cut out the fuel pump?YES!h2ggv wrote:would this cause the fuel pump not to run?
Grrrmachine
From here:
http://www.e30zone.net/e30zonewiki/inde ... or#Testing
"Getting a reading of approx 540 Ohms does not mean that the CPS is in working condition. However, NOT getting a reading means that the CPS is broken, and will need to be replaced. "
h2ggv
Thankyou will order new one in morning thanksGrrrmachine wrote:From here:
h2ggv
Yet again guys thanks for all the help got a very good used bmw cps of magpie this morning went and collected it this morning fitted it and straight back to life running great sound like its better on tick over before that might of sorted the tick over out.
The cps i had fitted was 3 weeks old do you think i will get a refund i will not be fitting another after market part. It took me nearly 2 days with breaking down and towing it home testing all the electrics on a part that's 3 weeks old its shocking. without the help from the forum god knows when i would have thought of testing a 3 week old part.
Yet aging guys thanks
Demand a refund!
G-Bear
Go on the Zone, a good turn around... and get a refund..
Refund plus expenses!
h2ggv
Expenses would be great 2 days of hell recovery and the car is still in bits 2 hours return jorney today to collect new part.Brianmoooore wrote:Refund plus expenses!
shocking i know will ring them later today
