Drop Link Bottom Bracket Replacement
Rousey66
Post Sun Aug 03, 2014 2:21 pm
So today I've been swapping some suspension components over and come to undo the anti roll bar linkage and the bolt holding the link to the control arm has sheared.
I've bought a new drop link however I'm struggling to find the bottom bracket with the sheared bolt anywhere. Does anyone know the correct name and part number or have a link to anywhere that has one in stock and available? As it's my main car the sooner I can get the part and fix it the better!
Cheers all!
Post Sun Aug 03, 2014 2:39 pm
Drill the remains out and fit a nut and bolt. You may have to grind the top of the bolt head down a bit to clear the link.
Bit late for you, if you've already bought new links, but if you'd gone for Mondeo links, you wouldn't need the bracket.
BMW part # of the bracket is 31 35 1 127 263
milescook
Post Sun Aug 03, 2014 5:55 pm
Hi Rousey i have a bracket and nut here... PM'd
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
Jozi
Post Mon Aug 04, 2014 12:54 pm
Brianmoooore wrote: Bit late for you, if you've already bought new links, but if you'd gone for Mondeo links, you wouldn't need the bracket.
What year Mondeo?
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Aug 04, 2014 1:00 pm
It'sin the Wiki, on the Bushes page.
Falamon
Post Mon Aug 04, 2014 1:02 pm
See here - http://ns1.e30zone.net/e30zonewiki/index.php/Bushes
You need these - Ford Mondeo estate Mk III (2000-20007) rear drop links.
Jozi
Post Mon Aug 04, 2014 1:10 pm
Thanks lads. But I'm a eejit, I blame the hangover, I had it in my head these would work on the rear arb but they are for the front and I've a different setup there.
Is there a known shorter droplink for the rear that anyone knows of?
