Hairyarse wrote:although not convinced it's going to sort all of my issues. We'll see
You are probably right here, I'm afraid. There are two versions of the SI board - one that uses non rechargeable lithium batteries and one that uses NiCd rechargeables.
The problems listed in the wiki are relevant to the NiCd version - these tend to go short circuit when they fail, pulling down the voltage supply to other instruments in the cluster and causing the problems listed.
The batteries on your board are solely to maintain the volatile memory circuit when the main car battery is disconnected, and don't do anything when it isn't.
The big orange sticker is pointing at a jumper link on the board that acts as a switch to connect the batteries, and indicates that your board was fitted as a replacement at some time in the car's life. Lithium boards fitted as original equipment at the factory didn't have the jumper link - they had a small wire link permanently soldered between two spare holes you can find on your board, near the jumper pins.
P.S. In your first pic. you can see a large 220 ohm resistor just beside the blue socket. Check the soldered connections for this resistor, which are near the temp. gauge on the print side of the board. If they've never been attended to, they will have deteriorated, and give rise to a fault with the brake pad warning light.
