camber/toe adjustments
ifty
Post Fri Jan 20, 2006 8:13 pm
Hi all
ive lowered my e30 cab by 40mm using G-max springs and dampers.Ive noticed the inner rear tyres are wearing out been told camber is out and need to change trailing arm bushes to the eccentric ones. Can someone please tell me the difference between the concentic bush and eccentric ones? and has anyone been able to sort this problem out to their lowered e30?? thanx
kam-325i
Post Fri Jan 20, 2006 9:55 pm
Basicaly, the "Camber Correction Bushes" that are fitted to the rear trailing arms are offset slightly to adjust the camber.
Although a 40mm drop should not really becausing a camber problem.
