hello,
I want to replace all sensor in my engine 325i motronic 1.3 1989-1991.
I have search in the wiki but can not find how many sensor attach to the thermostat housing?
I see at realoem that it is said 2 but in the other website I found 4 sensor.
ENGINE COOLANT TEMP SENSOR 1-POL 12621710512
Temperature sensor M12X1,5 13621709966
and
what is different between oil pressure switch for 325i with catalytic converter and without? which should I use?
03 OIL PRESSURE SWITCH M12X1,5 12/1986 61311354274 $14.96 Cat=Yes, +core
03 OIL PRESSURE SWITCH M12X1,5 1 61311354274 $14.96 Cat=No, +core
03 OIL PRESSURE SWITCH M12X1,5 1 12/1986 12611710509 Cat=Yes, +core, ENDED
03 OIL PRESSURE SWITCH M12X1,5 1 12/1986 12617568480 Cat=Yes, +core, ENDED
03 OIL PRESSURE SWITCH M12X1,5 1 12/1986 12617620512 Cat=Yes, +core, ENDED
Thank you before
markus
how many sensor attach into the m20 thermostat housing ?
markus_74
gromgsxr
should be 2 sensors, blue 2 pin for the ecu and brown 1 pin in connector for the temp gauge.
Number of sensors depends on the car's intended market. All should have the blue and brown, but some have an excess temp. switch as well, linked to the overhead panel.
The only variations I know of in oil pressure switches is the differing connector between pre and post facelift versions.
You're making a mistake replacing good sensors. A twenty year old good one is likely to be more reliable than a new one. These things follow a 'bath tub' reliability curve, where the twenty year old ones are mainly right in the bottom of the tub, while a new one is sitting on the rim.
Grrrmachine
- E30 Zone Wiki / Team Member
Care to put that into words us mere mortals will understand?Brianmoooore wrote:These things follow a 'bath tub' reliability curve, where the twenty year old ones are mainly right in the bottom of the tub, while a new one is sitting on the rim.
markus_74
hello, brianBrianmoooore wrote:Number of sensors depends on the car's intended market. All should have the blue and brown, but some have an excess temp. switch as well, linked to the overhead panel.
so if it is still good do not replace? I think the older the sensor will be worst.
thank you for the info.
- **BANNED**
The one sat on the rim is waiting to take a plunge!Grrrmachine wrote:Care to put that into words us mere mortals will understand?Brianmoooore wrote:These things follow a 'bath tub' reliability curve, where the twenty year old ones are mainly right in the bottom of the tub, while a new one is sitting on the rim.
As the actress said to the bishop....
reggid
i bought a new sensor and it shit itself in a week, kept flashing at me and leak out between the metal and plastic.
if you need a new one get the expensive replacement one not the one that cost about $5-10 (i.e. NOT FAE brand).
i now use a VDO one which can be hooked up to a gauge but it also keeps the dash light operational. Now the light on the dash comes on at a higher pressure (13psi vs 7psi) than the OEM one which is a little bit more of a warning.
E30 325is with M20B31
markus_74
hello, reggidreggid wrote:i bought a new sensor and it shit itself in a week, kept flashing at me and leak out between the metal and plastic.
i found some brand febi, behr, and gates for sensor and thermostat 80 does is it very good?
reggid
behr is usually a good brand
