What could be the cause of it?
can't see nothing in the dark no more......
Don't know if I am doing 100 or 10 mph
Just tried that mate, but no luckkam-325i wrote:Turn the side/headlight pull switch clockwise, it is also a dimmer for the dash lights....
will give that ago tonight.Brianmoooore wrote:Pull out the rear ashtray, and extract the little lampholder that illuminates it.
Turn the sidelights on and earth the brown/white wire.
Does this make all the lights come on?
Not if the RH sidelamps are working.BeemaBoy wrote:Could'nt it just be the fuse?
Good wiring diagrams and a lot of messing around with E30s.bigdek wrote:brian how do u know all this stuff m8. ?
Haven't you missed a bit of this story? Thought you didn't have any lights anywhere.lifegoeson wrote:now i can only get the rev meter to light up, the speedo doesn't light up?
thanks to you i resolved the first issue,Brianmoooore wrote:Haven't you missed a bit of this story? Thought you didn't have any lights anywhere.lifegoeson wrote:now i can only get the rev meter to light up, the speedo doesn't light up?
Well fill us all in then - what was it?lifegoeson wrote:thanks to you i resolved the first issue,Brianmoooore wrote:Haven't you missed a bit of this story? Thought you didn't have any lights anywhere.lifegoeson wrote:now i can only get the rev meter to light up, the speedo doesn't light up?
