Thanks,
JF
I had to do mine again after was done and was set to the torque specs. Mine was on the exhaust side of the sump. All Good now after 3yrsJF008 wrote:Cheers rich I think the bolts are loose can't see the gasket being shot already
That's the one for your car, but this thread is about an M50 one, which is a much more 'sophisticated' gasket.Mitchen wrote:
It's the one in the following pic right?
http://www.realoem.com/bmw/showparts.do ... g=11&fg=10
Sweet!!! check the sump again in about 2 mouths for leaks but you should be all goodJF008 wrote:Cleaned up and tightened, no leak
