m20 engine loom question, where this should be attached?
markus_74
Post Thu Jul 24, 2014 1:39 pm
hello,
need help where this plug should be attach? to the fuse box or there is somewhere connection?
Please see the picture
thank you
markus
Post Thu Jul 24, 2014 1:46 pm
markus_74
Post Thu Jul 24, 2014 1:56 pm
Speedtouch wrote:May be of use:
http://www.e30zone.net/e30zonewiki/inde ... tronic_1.3
Sounds like it could the C101 connector:
http://www.e30zone.net/e30zonewiki/index.php/C101
hello, speedtouch
yes, i have read wiki but i still don't understand c101 is connector to attach to fusebox? or to another loom?
does this picture is a complete engine loom or do I miss the other loom that attach to c101 connector?
of course I should need injector loom also.
thank you
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Jul 24, 2014 1:59 pm
C101 is the big connector NEXT to the fusebox in your car.
Post Thu Jul 24, 2014 2:07 pm
The plug in your pic. is the C101. The other big round one is the diagnostic socket.
As said above, it plugs in right beside the fusebox, and the loom from its socket goes to the fusebox, BUT, nearly all the wires (fuel pump is the exception) just pass straight through the fusebox and out into the cabin without connecting to anything inside the fusebox.
If your car doesn't have a 20 pin socket to suit this plug, then you probably have an early version of your body loom which had a rectangular socket with many less pins, plus a three pin socket under the dash for a couple of functions.
markus_74
Post Thu Jul 24, 2014 4:41 pm
i just check my car inside a plastic cover, yes I found a big round connector in side of my fusebox i think this c101 should attach to this.
my car is 1991 m40
thank you brian, speedtouch, grrrmachine.
Post Thu Jul 24, 2014 7:59 pm
All the engine loom connections to the car, except the main loom earth and permanent live go through this plug. Exceptions are connections to the small plugs near the ECU plug, on cars with a switchable auto gearbox and/or aircon.
Your engine loom will have extra wires fitted to the plug compared to the M40 loom. These are for the oil level sensor, which you won't be able to use.
