e34 525iX very sad day
looking back i shouldn't of scrapped her, if i knew what i did now then then she would of been in a better state!
I'm gonna take the B3 e36 beyond her 243,000 miles i think onl y 20k needed to beat it
Crank sensor has got the beast running again, a hard part to find it seems
Good to hear that, Si.
Jesus325iTouring
- Frog freak !
Cast iron bath, now they do weigh a bit!
Were you a proper man like me and remove it in one piece Si??
Looks broken up in the boot
Gives it a cool ride height.
When its that low it triggers the SLS warning! No Rog it was smashed into 2 big bits and heavy enough.
When we did our bathroom we had a cast iron tub and it weighed 120 kilos! i took it out whole i think, but not on my own
Top tatting!
Ive had two complete M52 engines in the boot of mine, but like a true executive tatter the SLS brought the ride height back up and I didnt get pulled by the old bill
My bro is now continuing the theme -
Andyboy
- Alpina Colada
Beginner.DanThe wrote:Top tatting!
Ive had two complete M52 engines in the boot of mine, but like a true executive tatter the SLS brought the ride height back up and I didnt get pulled by the old bill![]()
In my Compact I had an M44 and box, rear axle, front struts, zorst, wings, prop, four alloys, rad as well as a trolley jack and toolbox. I did remove the rear and front passenger seat.
Well the old girl was loaded on a trailer last night or this morning, 1 o clock!! And is now on its way to scotland where its fate is unknown but shes leaves with T&T
And one of it earning its money
I hope she stays on the road and mechanically its probably better than most iX's left on the roads now
Sold to another Zoner? You could at least have given it a quick polish!
Speedtouch wrote:Sold to another Zoner? You could at least have given it a quick polish!
Where its going, it will need more than a coat of polish !
indeed another zoner, i'll let him decide if he annouces himself as the proud new keeper!
chips innitDanThe wrote:Sorry, but this is -Speedtouch wrote:Try disconnecting either the ECU or battery, leaving it for an hour or so to reset the ECU then let it idle for at least 10 minutes to enable base idle settings to be learnt. Switch off, then take it for a drive throughout the rev range.
He's brave but not that brave !!Simon13 wrote:indeed another zoner, i'll let him decide if he annouces himself as the proud new keeper!
Topblag
It is with pride that I announce myself as the proud new owner. After buying a 911, I'm running my existing 525 IX as a daily driver and either the lpg setup will be swapped onto this one or the good bits from this one will be swapped onto mine.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
TPS
Good luck & well done Colin
Topblag
Given I use road muck instead of wax to protect the paint on my daily's , I advised Simon that his offer to wash it was kind but not necessary.Speedtouch wrote:Sold to another Zoner? You could at least have given it a quick polish!
I suspected it may have been you that bought it, but didn't want to say. Good luck with it - I'm sure it will come in useful.
