Ignition disable relay.
ah
Post Sat Jul 19, 2014 2:13 pm
The part no.61361588911 and its positioned under the plastic trim in the glove box.Can anyone give me some info on this relay as I think mine may be faulty.I need a up to date part no. as this one comes up with nothing.
Post Sat Jul 19, 2014 2:26 pm
Just an ordinary orange 4 pin relay. Only thing special about it is that it has provision for retaining lugs.
Same relay as lambda heater or fuel pump relay.
If you want to test the circuit, pull the two single plugs apart (top right of glove box area) with black/yellow wires and plug them together. This reverts the circuit to as it is on a manual car.
Unlikely that the relay is faulty - much more likely to be misadjustment of the switch on the gear selector.
