4 door and touring questions
alexbaby88
Post Fri Jan 20, 2006 11:51 am
Are the door skins and inner door cards the same from a 4 door saloon and a touring?
320Touring
Post Fri Jan 20, 2006 11:56 am
The full front door (inner trim panels and outer skin/glass) are the same on tourings and 4 doors
as for the rear doors, everything up to the glass is the same, but the touring has a different frame shape and glass.
so basically, any front door will fit, and the rear doorcards will fit, however rear doors could need a different glass frame dependant on application :D
hope that helps
alexbaby88
Post Sat Jan 21, 2006 11:51 am
Crystal. Thanks much.
