M20b25 not starting
shedrool83
Post Sat Jul 05, 2014 1:26 pm
Tried to start the project this morning for the first time since fitting the engine and its just cranking.
I have fuel at the fuel rail and spark
I removed an alarm that was in the rolling shell when i got it but i'm pretty sure i reconnect the loom as it should be plus i have fuel and spark so dont think its related to the old alarm .
Just looking for a few suggestion try for the next time i get a chance to try again.
The engine has had new cam belt ,dizzy ,rotor arm
Would £10 of fuel in an empty tank be enough?
Any ideas ?
Post Sat Jul 05, 2014 1:53 pm
If you have fuel pressure and sparks, then you either have a very serious mechanical fault, or the injectors have lost their 12 volt feed.
Post Sat Jul 05, 2014 1:54 pm
Yes, £10 of fuel should be fine. See the Zone Wiki:
http://www.e30zone.net/e30zonewiki/inde ... oubleshoot
You could also try spraying some carb or brake cleaner down in the throttle body while cranking the engine over - this may then draw the fuel through...
shedrool83
Post Sat Jul 05, 2014 6:03 pm
Sorted was a semi kinked fuel hose at the filter.
Post Sat Jul 05, 2014 6:04 pm
Nice one. 8) I had that problem once.
Post Sat Jul 05, 2014 6:05 pm
shedrool83 wrote:Sorted was a semi kinked fuel hose at the filter.
In that case you didn't have fuel pressure, otherwise it would have run.
shedrool83
Post Sat Jul 05, 2014 6:24 pm
I was getting fuel out the hose at the fuel rail Brian but not enough by the looks of it .
.I didn't have anything to check the fuel pressure.
Post Sat Jul 05, 2014 6:59 pm
In the absence of a gauge, you should try to block the end of the hose with your finger. It should be close to impossible to stop the flow.
shedrool83
Post Sat Jul 05, 2014 7:17 pm
Useful tip Brian i'll remember that.
