rear brake upgrade suggestions please
thed4ppa
Hi Keri I've sent an email as I'm after a front and rear brake set up, if you get a chance have a look at your mail!
keri-WMS
Just going through some email now - is that Jody?
keri-WMS
Good news - the T10 2-pot rear "E30" bracket bolts up to the E36 compact rear lugs (radial position to be confirmed though).
Bad news - the Compact rear hub face > lug offset is about 20mm more than the E30! So I need a new rear disc, or half of the handbrake shoes will be outside the back of the drum. Will have a look ASAP.
To be continued...
To be continued...
Tedswagon
Thanks for the update Keri. First half had me on hooks, second half not so much!
How big a problem is this? Daft laddy question alert: Can the handbrake shoes be changed for smaller ones?
Tedswagon
keri-WMS
If I can find the "same disc but deeper" it's fine, if I can't then it's a total pain!
If no disc can be found then it might be possible to make up spacers to move the mount points for all the hanbrake stuff 20mm or so off the backing plate.
keri-WMS
....we miiiight be ok, found a 14mm deeper disc with the same dims (inc drum diameter) - I'll have to do more checks though.
appletree
As you know Keri im also interested in a rear set up and upgrade to the front now I know I have the 1.38" piston front caliper
keri-WMS
Hi Matt, worry not, you're on the "rear" list - would you mind re-sending any emails to me as I lost everything since early last year! I've got all the PMs though.
Tedswagon - As of today my E36 compact rear corner is sitting with a 294 vented disc on it, the shoes are not perfect but good enough as far as I can tell so far. So the Compact rear 2-pot kit is a goer!
Tedswagon
Great news. I'm delighted. Let me know what I need to do next. Pm if you don't get a reply soon enough in here.keri-WMS wrote: Tedswagon - As of today my E36 compact rear corner is sitting with a 294 vented disc on it, the shoes are not perfect but good enough as far as I can tell so far. So the Compact rear 2-pot kit is a goer!
Ronan.
appletree
Im guessing they do but just to confirm do the rear kits need to have the backing plates cut to fit the discs in as i have not long fitted a brand new genuine set to my spare trailing arms...
Yes you will need to cut them, the whole of the lip needs removing due to the larger disc
Pics of Fergs below, I had them sandblasted and powdercoated after cutting them
Demlotcrew
Neat radius cut Dan!
appletree
Thing is mine are brand spanking new and I've already fitted the bearings! B****x would be a shame to cut them up when the old ones could have been cut as they were only tatty on the edge lip...
keri-WMS
I'm afraid both the E30 and E36 Compact versions will need the lip on the backing plate trimming down..
appletree
Any news on the prices yet keri?
I need to order a four line rear brake kit this week idealy otherwise it will be holding the job up.
Can you help with that?
Tedswagon
I'm happy to cut away, sounds like it's not that big a hardship for the gain.
Any idea about timescales for an order? Prices etc. ?
Cheers.
Cheers.
keri-WMS
Prices are here ( http://www.e30zone.net/modules.php?name ... c&t=209738 ) with the Compact estimate on page 2.
As we don't normally hold the 2-pot T10 caliper in stock, the lead time on the kits is rather variable. Probably 2 months, +/- 50%.....
In theory we can supply Earls 4 and 6 line kits, I'm waiting for a price list from them though.
Tedswagon
Hi Keri, been a wee while, hows it going???
keri-WMS
Sorry - I'm stuck waiting for a supplier, will be in touch as soon as I can progress this!
Tedswagon
No problem, just keeping in touch.
