Got a problem with my sunroof.
gooner1
Out humping Reindeer
Post Mon Jun 30, 2014 3:53 pm
Which began whilst trying to fit a wind deflector.
Roof opens perfectly normal, however when trying to close
it, it stops an inch before full closure.
Removed the wind deflector, as I thought the metal clips were
stopping the roof's progress.
Hasn't removed the problem. If I hold the plastic strip,
at the front of the roof aperture, down, then the roof will fully
close. Which is better but would rather have a fully functioning
roof, preferably with the wind deflector fitted.
Any ideas folk?
TIA.
gooner1
Post Mon Jun 30, 2014 6:33 pm
Just to explain a bit better than before.
It's the plastic strip that runs horizontally at the front
of the sunroof aperture that is causing this.
It's supposed to lower as the sunroof closes, it doesn't
do this unless I physically move it down.
jonny323i
Post Mon Jun 30, 2014 6:50 pm
It's probably just got a little bent as it's metal mine used to do the same just push down hard in her middle while it's open should cure it
Touring for life
gooner1
Post Mon Jun 30, 2014 9:01 pm
Tried that jonny, no joy.
Also tried the same with the 2 arms that attach to it on either side.
Anyone else had problems after fitting/trying to fit the persplex wind deflector?
jonny323i
Post Mon Jun 30, 2014 9:02 pm
I think some pictures might be needed
Touring for life
gooner1
Post Mon Jun 30, 2014 9:09 pm
Will take some tomorrow.
Once I get it sorted, I think I'll tigerseal the f^$*£"g
deflector to the roof. Grrrrrrr.
jonny323i
Post Mon Jun 30, 2014 9:11 pm
Iv had them before on fords and the brackets are so thin they shouldn't affect anything else
Touring for life
gooner1
Post Mon Jun 30, 2014 9:18 pm
http://www.realoem.com/bmw/showparts.do ... g=54&fg=05
No2 is the part that has caused the problem.
Part 8 is the part that now won't close unless I hold
it down while operating the sunroof switch.
jonny323i
Post Mon Jun 30, 2014 9:23 pm
It's going to be something silly like something unclipped
Touring for life
gooner1
Post Mon Jun 30, 2014 9:26 pm
Or unhinged, like the bloke trying to fit it. :)
