One for the tuning guru's.
I need to set up my spark tables on megasquirt as my mpg is really crap. Afr's are fine but timing is off I guess. If anyone can help that would be great
help with setting up megasquirt
gromgsxr
you could lean out your aft targets a bit and re tune the bottom part of your ve table so cruise is a bit leaner save some fuel there
rich318i
guessing your block is a m20b25?
gromgsxr
i think its a 1.6l 4pot engine
rich318i
total waste of time then
gromgsxr
i think a target cruise aft 0f 13.5-13.9 afr is way richer than you need and will cost a fair bit of fuel 15-16 afr would be better, using orfc will help a little and you warm up enrichment looks fat, my m20 does not need any extra fuel after the coolant reaches 27c so if you tune your warm up may help. and i think you ego switch point voltage should be closer to 2.5 volts as well
cypriot_boy_2k7
ORFC?gromgsxr wrote:i think a target cruise aft 0f 13.5-13.9 afr is way richer than you need and will cost a fair bit of fuel 15-16 afr would be better, using orfc will help a little and you warm up enrichment looks fat, my m20 does not need any extra fuel after the coolant reaches 27c so if you tune your warm up may help. and i think you ego switch point voltage should be closer to 2.5 volts as well
My fuel table is set up great. Idle at 14-15 afr and under full boost 12.3 -13.2 afr off the top of my head.
My spark table may be the issue after speaking to a few people on megasquirt forum.
Hmm you would know I take itrich318i wrote:total waste of time then
gromgsxr
yeah i saw the post on msextra and iv seen you msq. Over Run Fuel Cut, and like i said ur afr target table is rich from your data log at say 2800-3000 rpm cruising at 4% throttle the afr is 13.5-13.9 you could be 15-16 in that area.
cypriot_boy_2k7
Did you see the latest data log? Whats your username on there? When ive finished putting it all back together I will get a new log and go from there
gromgsxr
yeah i saw the latest one, may wanna look at your ae setting it goes pretty lean on tip in, i'm grom_e30 on there. il keep an eye out for the log and current msq.
cypriot_boy_2k7
Thanks for your help, I'll be in contact when things are up and running againgromgsxr wrote:yeah i saw the latest one, may wanna look at your ae setting it goes pretty lean on tip in, i'm grom_e30 on there. il keep an eye out for the log and current msq.
