Tow strap location
327ire
Thu Jun 26, 2014 2:54 pm
I will be deleting my front bumper shocks and fitting a light weight fibreglass bumper and apron...
The bumper shock assembly will be completely removed and replaced with a small bracket to fit some quick release things. (thanks to someone on here for the idea!) Where should I fit a tow strap to the front of the car now that Im removing the tow eye?
Altrezia
Thu Jun 26, 2014 3:32 pm
Mount it to the front of the chassis rail and poke it through a hole in the bumper - perhaps cut one for it?
327ire
Thu Jun 26, 2014 5:05 pm
The front of the chassis rail, so use one of the bolt holes thats used for the bumper shock?
ross_jsy
Thu Jun 26, 2014 6:05 pm
Was it my popper idea? If so, I'm just going to mount a tow strap through the existing bolt holes used for the bumper shock
327ire
Thu Jun 26, 2014 6:20 pm
Yep it was your idea ross, Iv just ordered the bits required. Ill weigh everything when Im doing it but Im hoping for a substantial loss, probably the equivalent to converting to a carbon bonnet.
Ill use the bumper shocks holes for the strap then, thanks!
ross_jsy
Thu Jun 26, 2014 6:22 pm
I lost around 7.2kg, considerable weight given how far forward it is!
GB69
Thu Jun 26, 2014 6:35 pm
Bolt it to the chassis, and cut a rectangle in the bumper so strap can be pull straight.
Demlotcrew
Fri Jun 27, 2014 9:04 am
Im not sure if using one of the existing m8 vertical bolt holes is such a good idea, sure the car will pull on level ground, and possibly even make it out of a gravel trap, but it sure as hell wont make it up a flatbed or trailer.
327ire
Fri Jun 27, 2014 10:02 am
Demlotcrew wrote:Im not sure if using one of the existing m8 vertical bolt holes is such a good idea, sure the car will pull on level ground, and possibly even make it out of a gravel trap, but it sure as hell wont make it up a flatbed or trailer.
What would you suggest?
327ire
Fri Jun 27, 2014 10:05 am
ross_jsy wrote:I lost around 7.2kg, considerable weight given how far forward it is!
In an e30 it's THE ultimate place to loose weight. A bonnet is high on my list for the same reason.
Demlotcrew
Fri Jun 27, 2014 10:28 am
I would weld an eye bolt plate to the upper or lower section of the chassis rail.
http://www.demon-tweeks.co.uk/performan ... bolt-plate
This will give you the best possible strength and alignment when the strap is under load.
On my own car, I just modified the stock bumper mounts to reduce as much weight as possible but still keeping the stock bolting system. Then a cheapo towing eye from ebay. Its only screwed in when in use, on track its off.
GB69
Fri Jun 27, 2014 7:05 pm
Mine use both the bolt holes. It was done like this:-
Was enough to pull me out of a ditch.
327ire
Sat Jun 28, 2014 10:01 am
In that case, it must be ok then!
