Retrofitting Interior Light Delay Unit
bhavin_10
Post Wed Jun 25, 2014 2:44 pm
Hi i need help installing Retrofitting Interior Light Delay Unit.
i have done what it says on http://www.e30zone.net/e30zonewiki/inde ... Delay_Unit
But still no luck.
Has anyone done this upgrade?
Post Wed Jun 25, 2014 7:19 pm
Done the bit referring to the exterior door handle switch?
bhavin_10
Post Wed Jun 25, 2014 11:16 pm
I've tried to but it was confusing :?
Could you explain where I should cut the wires and which part of the wire should be joined where Please
Post Thu Jun 26, 2014 10:31 am
From my own notes: "To retrofit interior light delay module, disconnect brown/purple from RH door switch, and replace with brown/yellow (spade connector) taped up with brown/purple single male socket.
Connect brown/purple (ex. door switch) to this socket.
If no door handle switch is fitted, connect TK and TG pins on the module together."
I normally connect the pins together by opening up the module and soldering a wire link to the circuit board, since this involves no bodging of the loom, but it can be done externally by cutting the brown/green a couple of inches from the socket, then splicing this two inch wire to the brown/yellow wire.
If you want the module to work on the passenger door as well, you need to disconnect the brown/purple from that as well, and run a wire from the switch to connect to the brown/yellow as well.
