Nearly Non existant clutch
craigieeb
Post Sun Jun 22, 2014 11:57 pm
bit of a head scratcher going on here,
I was running the ZF type gearbox (removed from an E36)
that died and I have replaced it with another ZF box from an E46,
Ive used the exact same equipment from the old set up,
slave, release bearing, clutch fork,
and now the clutch biting point is on the floor..? where as before it was perfect,
i.e hardly any pedal travel before, and now there is a good few inches before there seems to be any pressure..?
the weird thing is, the part numbers on both gearboxes are exactly the same,
the slave was only unbolted from the box and not undone from any pipework, so no air has got into the system.
anyone got any suggestions?
craigieeb
Post Mon Jun 23, 2014 10:46 am
Well,
came out this morning to find a nice pool of clutch fluid under the car,
and an empty reservoir but all the pipes are bone dry,
so i'm thinking the slave might be leaking from the seal...?
I'll pull it out later on and investigate
Post Mon Jun 23, 2014 12:21 pm
Sounds like it, change the master too while your on
craigieeb
Post Mon Jun 23, 2014 12:36 pm
But why? Lol
There's no fluid or evidence there is any leaking from it
and the pool of fluid was on the slave side dude.
Post Mon Jun 23, 2014 12:43 pm
Have you changed it recently? Ever?
craigieeb
Post Mon Jun 23, 2014 12:50 pm
No and no :)
Post Mon Jun 23, 2014 12:55 pm
Change it then :)
jmc330i
Post Mon Jun 23, 2014 1:45 pm
As Dan said, change them both. If you only change one, chances are you will be changing the other within a month - the master on mine lasted almost a week after I changed the slave!
James
'91 325i Sport
'93 318i touring 16v
craigieeb
Post Mon Jun 23, 2014 7:06 pm
EH!!!! :wtf:
Just pulled the slave off, and there's no trace of fluid anywhere, nothing at all
so I'v changed it anyway, filled the reservoir bled it, bled it and bled it, and is back to normal
that's got me baffled like!!
even when i was pushing the slave rod in and out, there was no fluid coming from anywhere :?
fook it, if it's working then it's fooking working
HairyScreech
Post Mon Jun 23, 2014 10:17 pm
How olds the clutch hose? I thought I had a cylinder on the way out the other week, one nice new braided hose later and no more clutch slop.
I think a lot of these cars have had new slaves etc but no ones touched the lines since they were built.
maxfield
Post Mon Jun 23, 2014 10:21 pm
I've had it a couple of times on BMWs where doing the gearbox I've caught the slave cylinder and it's caught the seal and leaked after.
craigieeb
Post Mon Jun 23, 2014 10:38 pm
HairyScreech wrote:How olds the clutch hose? I thought I had a cylinder on the way out the other week, one nice new braided hose later and no more clutch slop.
It's still the standard hose for the moment,
I was going to change it for a nice shiny braided one, but wasnt sure which to get,
I was under the car while i had the missus pumping the peddle :)
and there was no leakage or "ballooning"
but what I have noticed..
when you pop the slave rod out of the outer rubber, I can see fluid, inside,
are you supposed too? or is there in inner seal also??
craigieeb
Post Mon Jun 23, 2014 10:39 pm
maxfield wrote:I've had it a couple of times on BMWs where doing the gearbox I've caught the slave cylinder and it's caught the seal and leaked after.
There's no "nicks" or anything in the outer rubber, but see above lol
HairyScreech
Post Mon Jun 23, 2014 10:42 pm
cant really advise the hel one, good quality but the length/bend is a bit off so it leads to the cylinder being upside down and a bit hard to bleed, when bled its nice though.
Post Mon Jun 23, 2014 10:55 pm
Seal you can see is just to keep muck out. The real seal is at the inner end of the piston, and all fluid should be behind it.
In normal use, a ridge of debris builds up at the limits of piston travel in both the master and slave cylinders. If for any reason, such as a fluid leak, dismantling of parts, or even bleeding, the pistons move past their normal limits, the seal gets pushed into this debris, and if the rubber is in anyway past its best, it's likely to be damaged. Dislodged debris from the master can also find its way down into the slave and wreck the seal there.
These are the reasons that it's recommended to change both cylinders at the same time.
craigieeb
Post Mon Jun 23, 2014 10:57 pm
Yeah, I seem to remember buying a goodridge hose years ago for the M20, and found it was too short,
so that put me off a little, and with me now having the ZFbox and E46 slave in the E30 I wouldn't know what length to get :mad:
anywhoo, to answer my own question :)
craigieeb wrote: when you pop the slave rod out of the outer rubber, I can see fluid, inside,
I've just dissected the slave on the com desk, and the outer rubber seal seems to be just a dust boot,
as there is a rubber sealing ring on the piston inside the cylinder,
so I shouldn't of been seeing fluids just inside the dust boot :D
(if that makes sense :mad:
craigieeb
Post Mon Jun 23, 2014 10:58 pm
Brianmoooore wrote:Seal you can see is just to keep muck out. The real seal is at the inner end of the piston, and all fluid should be behind it.
HairyScreech
Post Tue Jun 24, 2014 1:42 pm
[quote="craigieeb"]Yeah, I seem to remember buying a goodridge hose years ago for the M20, and found it was too short,
If you are using the stock E30 hose then I would assume that's the length you want. winkeye
Otherwise I might be able to let you know soon, Iv got one with a leggy box and possibly a grumpy diff so my thinking is to go to a newer ZF box and a medium case z3 diff.
