Got a bit of a running issue I can't get to the bottom of.
About 2 months ago the car started missfiring under load at around 5k, it was intermittent but when it happened it was like hitting the rev limiter.
Changed the fuel pump and the problem seemed to clear up.
Recently I have been getting a slight hesitation, inconsistent but certainly present, doesn't seem to be at any one point in the range or temperature related.
I thought this might be fuel related again and had a sniff around the filter, one 1989 vintage filter replaced and out for a run to work this morning.
Seems I still have a hesitation and after sitting at a set of lights changing to 2nd resulted in such a back fire I actually crawled under the car when I got to work expecting to see some serious damage.
I checked the basics when I started looking for the misfire, blue sensor I believe is ok (6 months no more) and I have checked the plug under the manifold, the TPS gives the idle position click, crank sensor is fine, no difference in the starting behaviour.
I put a new Bosch coil on it as they were cheap from ECP so its not the coil.
Pulled plug 2 and 4 yesterday and both look clean as a whistle, put a boroscope in there and there's a healthy mm or so of carbon on the piston tops so I'm ruling out a real solid problem like a failed blue sensor or dead maf.
A bit of research says that there should be no lambda relay in the DME box as there is no sensor on the car, I believe one has been there from day 1, (had this one quite a while).
Any ideas what could be causing this?
I'm going to check the ICV and MAF later on.
