Wheel spacers?
Stevieabz
Wed Jun 18, 2014 11:31 am
I want to get some wheel spacers for my 1987 325i Sport. Could anyone suggest a nice size and brand? I don't really know who's who and what's what. Any advice would be great.
ross_jsy
Wed Jun 18, 2014 11:41 am
Why do you need wheel spacers and what wheel sizes are you using? That will determine what size you need
Stevieabz
Wed Jun 18, 2014 11:57 am
The word need was never used :teehee: No one NEEDS spacers, I just want them :) And I have 15" wheels at the minute, if that's what you meant by size? I kinda meant what size spacers as in the thickness of them 10, 15, 25mm ect. Thanks
dirtee-herbert
Wed Jun 18, 2014 12:00 pm
People will need to know the wrong the wheels and maybe even the tyre size you are using and what kind of look you are going for. I.e. A bit of poke of you just want the wheels to be a bit more flush.
Some pics would also be useful man :)
dirtee-herbert
And the rim width. I missed the main one.
ross_jsy
Wed Jun 18, 2014 12:03 pm
I don't think you understand the point of spacers, people do need them, for example to clear struts or callipers.
So what exactly do you want them for then if it's not a clearance issue :?
By wheel size I mean width and offset, if you don't know those then we might be able to help by what wheels you have
Grrrmachine
E30 Zone Wiki / Team Member
Wed Jun 18, 2014 12:27 pm
Wheel spacers are discs of metal. There's no better or worse brands.
However, all are worse if they move the wheel centre away from its intended position relative to the hub. Just pushing the wheels out will bugger up your geometry and make your suepension wear out quicker.
If you're doing this for reasons of poke, stance or flushness, then grow up and learn that wheels are for keeping you connected to the road, not for impressing low-trousered mongoloids.
Wed Jun 18, 2014 12:30 pm
Be aware that if you fit spacers of a certain thickness, you'll also need longer wheel bolts to ensure that there's enough thread remaining in the hub to hold the wheels on!
Also be aware that spacers can sometimes throw the balance out, and put more load on the wheel bearings, so they will wear quicker.
Stevieabz
Wed Jun 18, 2014 12:34 pm
Okay I defiantly don't understand spacers. let me gather some info and I'll get back to you guys
Wed Jun 18, 2014 1:20 pm
GB69
Wed Jun 18, 2014 7:10 pm
Driftworks can make anysize you want, I got 50mm hubcentric from them.
Also got some 25mm hubcentric spacers off ebay.
