m50 turbo oil return
ross_jsy
Fri Jun 06, 2014 8:31 pm
Just thinking out loud really, does anyone think it would be possible to return the oil feed to the timing chain cover?
Reason I ask, it looks like getting the sump off is going to be a nightmare with the engine in the bay
Fri Jun 06, 2014 9:05 pm
Simple enough to return it via the dipstick
ross_jsy
Fri Jun 06, 2014 10:00 pm
Good call, bit of a convoluted route but I am sure I can make it work
Driftben
Sun Jun 15, 2014 11:09 am
in a perfect situation you really need to make the oil drain lower than the turbo itself so its easier for the oil to gravity drain back to the sump if that makes sense?
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
ross_jsy
Sun Jun 15, 2014 12:13 pm
Yeah I don't want to run a scavenger pump so it will be below the oil drain level.
My manifold and turbo are on their way to me so hopefully have them next week some time so I can start mocking up
Driftben
Sun Jun 15, 2014 12:47 pm
what turbo have you gone for?
I'm welding two AN10 fittings into my sump above the oil level for my drains from the turbos.
AN4 to supply them and AN10 for oil return to the sump
6pot wilwoods front
4pot Porsche rear
ross_jsy
Sun Jun 15, 2014 1:02 pm
Holset HX40 18.5cm2, quite a sizeable beast :D
I plan on using AN10 for the drain, I measured the dip stick tube and it's about 5mm smaller than AN10 though. I think I am going to have to bit the bullet and pull the sump off :(
maxfield
Sun Jun 15, 2014 3:40 pm
Do it once and do it right. Whip the sump off and weld AN10 fitting in there for a proper job.
ross_jsy
Sun Jun 15, 2014 10:00 pm
What's it like taking an m50 sump off with the lump in situ?
leeparkes
Sun Jun 15, 2014 10:28 pm
Id go into the chain cover
Quaser
Sun Jun 15, 2014 10:51 pm
sorry to thread hijack - but I have a borg warner s256 - I was looking at a an12 return - is this overkill? anyone know what I need for the turbo oil inlet and outlet by any chance?
Q
ross_jsy
Mon Jun 16, 2014 1:38 am
an10 seems to be the norm for all the build threads I have been reading (and I have been reading A LOT)
ross_jsy
Cheers Lee, that looks like a decent solution and will save me pulling the sump
Driftben
Mon Jun 16, 2014 7:23 am
Iv seen that be done before but just remember the drain needs to be lower than the turbo otherwise you will get a oil failure,
For a oil feed I'd go for AN-4. Usually there's a oil restricter on the turbo oil feed line anyway
6pot wilwoods front
4pot Porsche rear
