dash problems! :(
Josepi
Post Thu Jun 12, 2014 10:30 am
Hi, my tach, mpg and clock still won't work, I've changed the si board, checked the loom connection, that's fine. Check fuse 10 and 21.... And can't see anything wrong with the wiring?! Anyone got any other ideas? Pretty sure the si battery are ok as service lights all come on with ignition and go of once started. Doin my nut in now
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Jun 12, 2014 10:48 am
When you say "check" the fuse, it's worth swapping them as they can soft-blow, meaning they break without looking broken. It's been the cause of more than one niggle on my own car.
Josepi
Post Thu Jun 12, 2014 3:41 pm
Yeah, 10 and 21 looked a bit tiered so I changed them for new ones... Stumped
SilverShadow
Hartge Crew
Post Thu Jun 12, 2014 3:56 pm
I had issues with my instruments this week.. I dismantled all down and checked for loose connections, greased all moving parts and it seems to be working fine now.
Josepi
Post Thu Jun 12, 2014 10:10 pm
Did you take the dials out? Where can be cleaned and regreased? Cheers
SilverShadow
Hartge Crew
Post Thu Jun 12, 2014 11:20 pm
I took the dials out, inspected the gears and soldier connections etc
sprayed some easy grease or we 40 on moving parts.
just make sure you use latex gloves when handling the dials as any marks will be difficult to remove especially if you get we 40 on it.
Post Thu Jun 12, 2014 11:57 pm
Analogue clock is not affected in any way by the SI board or the instrument cluster.
It gets its power from fuse 21 and is earthed at the stud behind the glovebox.
Take the clock out, pull off the pplug and connect a small 12 volt bulb between the brown and red/green wires.
