Exhaust Manifolds now done, Y piece fitted, and Middle Box now in. No Backbox yet, that will be done after the new bodykit is received and fitted. I had a retard moment, thinking the only adjustment on the BC coilovers was to compress the spring, then found out about adjusting the lower nut and so ride height was raised 30mm as it was too low. Brake Servo relocated to under the passenger side dashboard. A Brake Bias Valve was fitted into the rear lines, then into the Hydro. Brakes done, and bled and so the customary Burnouts commenced.
Burnouts:-
[youtube][/youtube]
Could prob do with going a little lower.
