Just a quick question regarding brakes. I have a1990 316i LUX 2 door coupe, no ABS. My brakes tend to do little until I'm almost stood on them. As a result they're not the most reassuring things to use especially in the wet. There's still plenty of disc & pads on the front. The drums are squealing a little but not constantly, just on and off occasionally.
Is this just a case of fitting new discs/pads on the front and bleeding them then putting new shoes in the back? Or are the brakes on the baby E30s just that bad?
This may be a dumb question. I'm not the most mechanically minded person in the world, servicing and nut & bolt jobs are about as far as I can do, so here goes. Is it possible to put a set of bigger, vented front discs & calipers off the 6 pots onto mine and how easy is it? I wasn't sure whether the lack of ABS etc. would cause issues or not. The same for doing a disc conversion on the back. How simple is it?
I'm aware it's only a little 1.6 so speed isn't really a factor. I'd just like a little more confidence. I'm bracing myself for all the "grow a pair" style comments by the way.
If not, are there any better quality discs & pads or shoes for the back you'd recommend in place of doing a complete replacement?
