EBC discs and pads ?
rich318i
Fri May 30, 2014 10:02 pm
Are they any good or just marketing hype ?
Any tried and tested reviews ?
maxfield
Fri May 30, 2014 10:09 pm
Never rated EBC I've had red and green. Greens didn't seem any better than standard pads. Reds squeak when cold and I managed to cook a set on a B road blast. Also with ebc the powder coat on the pads is always way too think and needs filing to get the pads in properly.
Ferrodo DS2500 is what I last used in my E30, never managed to cook them. They are a very metallic compound, they kill discs also plenty of brake dust.
Just my opinion though
Fri May 30, 2014 10:13 pm
i fookin hate brake dust !
greens ftw .
ross_jsy
Fri May 30, 2014 11:19 pm
Turned my yellows into charcoal after a b road blast, wouldn't use them again although they have apparently improved a lot.
+1 for DS2500's, I use 3000's (track only, but not too bad from cold) and a friend uses DS2500's in his 750hp Evo x and loves them
rich318i
Fri May 30, 2014 11:28 pm
How about the discs or rotors as the yanks like to call them?
jmc330i
Sat May 31, 2014 12:02 am
I used the EBC grooved and dimpled discs once (with green pads). The discs lasted only a few months before the surface started to crack between the grooves and dimples and I didn't drive hard a lot, just the occasional B road blast. I changed them after I noticed the cracking and haven't used EBC since.
James
'91 325i Sport
'93 318i touring 16v
zaust
Zone day release
Sun Jun 01, 2014 9:14 am
I use ebc yellow pads and like them but there discs are to be desired. Went back to tar ox.
M30 Tech 1 Touring on gas.
**BANNED**
Sun Jun 01, 2014 1:24 pm
I use standard discs,either EBC or whatever GSF supply,with EBC green pads.
Just fitted new discs/pads to the front of the touring,I took off the same combination...they had lasted 5 years/50K+ miles.
The touring had new rear brakes a while back,took out Padgid pads and fitted EBC green with new standard discs,the padgid pads,on the rear,remember,only about 40k miles.
Youth is wasted on the young.
pnd
Sun Jun 01, 2014 2:23 pm
best pads for dust!
maxfield
Sun Jun 01, 2014 2:30 pm
daimlerman wrote:I use standard discs,either EBC or whatever GSF supply,with EBC green pads.
You get 50k miles to a set of pads? :eek:
**BANNED**
Sun Jun 01, 2014 2:34 pm
Driving style will make a difference,I can also wring 36mpg as well as recording an average 55mph from Lincoln to Norwich!
M3Jim
Mon Jun 02, 2014 5:03 pm
Ive said it before but......Having used various different combos over the years I am very impressed with EBC. I run yellowstuff with their own discs and after 2 years of use and 2 track days they are still performing very well! I can assure you they have had a lot of abuse too!
miniblob
Mon Jun 02, 2014 6:07 pm
I'm currently using EBC 'OEM' discs and yellowstuff pads (and new fluid!).
Would rate them both as pretty average tbh, though it may be the discs letting them down, from what I've read before.
Discs seemed to warp a bit at the start, but went straight again after a bit of use (brake judder came, then went again!!!) and are now fine.
Pads are better than I expected from cold, but don't really seem to get any better when hot either. Not the best brake setup I've had by any means!!!
Best I've used was OEM discs from stealers and Ferodo DS2500 pads!!!
327 Touring with bass!!!
SStuart
Wed Jun 04, 2014 3:45 am
My current set up is EBC drilled and grooved discs F&R and greenstuff pads.
I am not confident in the braking both cold and hot.
I have also noticed a large volume of brake dust.
I will re-look at the installation to confirm the issue is pads (as suspected).
I am debating between EBC yellowstuff (previously been satisfied by this set-up) & DS2500's.
Is anyone is running EBC discs with DS2500's?
**BANNED**
Wed Jun 04, 2014 7:40 am
SStuart wrote:My current set up is EBC drilled and grooved discs F&R and greenstuff pads.
The disc's are probably your problem,try old-fashioned plain one's.
SStuart
Wed Jun 04, 2014 7:46 am
If i get no joy tweaking the current set up, Ill give it a go & see what the result is.
initial_g
E30 Zone Moderator
E30 Zone Moderator
Thu Jun 05, 2014 8:12 pm
Ive tried yellow and red suff, absolutely usless!!!!!!! Ferrodo 2500 are where its at.
initial_g
E30 Zone Moderator
E30 Zone Moderator
Thu Jun 05, 2014 8:14 pm
Im using ebc corrado g60 drilled disks and ds2500 it stops on a dime, I used the disks with red stuff and it was crap!!
ross_jsy
Thu Jun 05, 2014 8:51 pm
I forgot, I had EBC discs on for 2 weeks but I got them hot (I'm not talking track hot, but the pedal was going long) and pulled into a mates who wanted to sit in the car and have a look. Daft pr!ck left his foot on the brake and they warped really badly. Not really a fault of EBC but they weren't great anyway
SStuart
Fri Jun 06, 2014 5:17 am
While there appears to be a lot of debate on EBC pads, there's
more confidence and good reviews over the EBC/DS2500
combination.
Having spent a pretty penny on the EBC discs, I'm inclined to
give the above combination a try before anything else.
keri-WMS
Mon Jun 16, 2014 4:13 pm
We get far better customer feedback on DS2500 than EBC Yellow/Red etc....
Mon Jun 16, 2014 7:54 pm
Not completely relevant as this is for my E39 touring but I fitted new pagid discs and pads last year and they are now nearly out, less than 20,000 miles, 2 days after washing the car the wheels are black with dust, im hacked off TBH, they were never that bad when I used to run them on my daily E30 years ago, im thinking they have changed the compound with the ECP/Pagid connection, for the worse obviously...
George
Tue Jun 17, 2014 9:04 pm
DanThe - I remember buying a set of Pagid 'fast road' pads a while back for my E36. Good bite certainly but were as dusty as a dusty thing. I think I paired them to Brembo Max discs (do they still even make these?)
I've read plenty of negative reports re EBC for me to avoid them.
I've always found OEM ATE discs/pads from ECP to be adequate. Of course, if you are tracking your car, that's a different ball game.
