325I radiator with air con and not
markus_74
Post Mon May 26, 2014 6:51 pm
what make different between air cond radiator and non air cond radiator?
17111712823 and 17111712484.
can I use non air cond radiator for my car that is use air conditioning?
asking this because this is far more cheaper to use non air cond radiator than use air cond radiator.
and what is negative effect? does it will make my car overheat or there are no temperature switch option to plug into the non air cond radiator?
thank you
markus
jonny323i
Post Mon May 26, 2014 6:55 pm
An Aircon radiator is a lot larger the same as a tropical rad.
If you have Aircon I personally would only recomend using the proper rad
Touring for life
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon May 26, 2014 7:43 pm
The non-aircon and tropical radiators are much larger, because the aircon condensor sits in front of the standard-sized radiator and blocks it completely. Considering 325i's crack their heads if they overheat, it is not worth the risk of running a smaller sized radiator than recommended.
A tropical radiator might be cheaper than an aircon one, and that's whatI used.
jonny323i
Post Mon May 26, 2014 7:46 pm
My Aircon rad was only £80 from Ecp
Touring for life
markus_74
Post Tue May 27, 2014 2:59 am
Which one please?
Radiator A=440MM 1 09/1987 17111712823 $432.62
For vehicles with
Hot-climate version
S823A=Yes
or
Radiator A=550MM 1 09/1987 17112241912 $559.60
For vehicles with
National version Auatralia
L810A=Yes
01 RADIATOR WITH TRANSMISSION OIL COOLER A=550MM 1 09/1987 17111712484 $599.29
For vehicles with
Air conditioning
S530A=Yes
01 Radiator 1 09/1987 17111712850 $529.08
Grrrmachine
Post Tue May 27, 2014 5:46 am
I used 17112241912
jonny323i
Post Tue May 27, 2014 6:46 am
http://www.eurocarparts.com/mobile/ecp/ ... db5&000261
They are cheaper when they have an offer weekend
Touring for life
markus_74
Post Tue May 27, 2014 9:42 am
Thank you
markus
markus_74
Post Tue Jun 17, 2014 12:43 pm
jonny323i wrote:http://www.eurocarparts.com/mobile/ecp/ ... db5&000261
hello, I have contact them but the radiator you said is for bmw X5, does is it correct?
can X5 radiator fit into e30 car?
Core Dimensions 590X 589 X 26 mm
are you sure that the radiator part number from your catalog 203111420, is bmw 1439103 part number? that is for bmw X5?
jonny323i
Post Tue Jun 17, 2014 1:14 pm
I used their forum and chose it from my reg which is a 325i tourer
What's your reg I will check
Touring for life
Mitchen
Post Tue Jun 17, 2014 5:56 pm
Bare in mind EIS are a pile of shit, and if u get a year plus out of them you've done well!
1990 320i Coupe SE
viewtopic.php?t=253048
markus_74
Post Wed Jun 18, 2014 2:30 am
Grrrmachine wrote:I used 17112241912
Does your radiator has a small inlet/port/hole to install air con temperature switch in the right side of the radiator?
Grrrmachine
Post Wed Jun 18, 2014 6:08 am
Yes markus, my radiator has the inlet port.
markus_74
Post Fri Jun 20, 2014 7:02 am
Grrrmachine wrote:Yes markus, my radiator has the inlet port.
Thank you, so i can use it to attach my air cond switch.
