Hi,
Im looking to buy some polly windows for a coupe, probs sliders rather than leave my up/down windows in?
I may also want to add rear quater or rear window scoups for rear rad set up can these be bought and added after?
Anyone have a good company/advice
Id like to keep them in my rubbers rather than bolt on to frames, will they just blow out?
Lexan window kits
rix313
- Contact:
There's plenty of threads on this subject in this section. I have Templar Performance hard coated thermo formed door, quarter and rear windows, with a slider in the drivers door. Excellent quality and extremely good service.
rix313
- Contact:
Yes these ones I have all fit in standard rubbers. Easy Peasy to fit no messing about with cheese wire and glue. Standard windows don't pop out of the rubbers ;) I'm not entirely sure what the weight of a standard set of glass is compared to these to be honest. If any one has done the weighing I expect it's Andrew? I was a bit dubious about doing it properly is fairly expensive unless you buy a cheap none hard coated/heat formed set which scratch at the mention of it and need bodging in because they don't fit the rubbers.
