double sided issue
SHAKEELE30
Boost Junkie
Post Thu May 15, 2014 2:12 pm
ive been trying to use a double sided tape to stick my number plate onto my car, but end up loosing the plates as they just keep coming off...
can anyone recommend a double sided tape, ive used the green one, another white foam type called sellotape...
any others?
ross_jsy
Post Thu May 15, 2014 2:31 pm
The 3m stuff is what I have always used with no problems
afromaan
Post Thu May 15, 2014 2:32 pm
Try the 3m foam strips from whsmiths. I've used them before and they are perfect.
bdx
Post Thu May 15, 2014 3:08 pm
3M VHB
Post Thu May 15, 2014 5:01 pm
Strips were probably OK - it's the surface preparation that's important. If you stick the strip to a film of whatever is on the base material (bumper, rear panel, or numberplate) the strength of the bond is the strength of the bond between the film and the base material.
scallyally
Post Thu May 15, 2014 6:08 pm
Used to work for Avery Automotive at Thurrock and their range of d/s tapes were very good, particularly "666" and if surface prep was good and clean (and I mean clean!) you could not budge it (excessive heat might)
3m is good but foam tapes have to rely on the "shear" strength of the foam. Good luck :x
capnmchl
Post Thu May 15, 2014 7:39 pm
I've noticed with my front one it's not the actually sticky part of the tape that's failing, it's the foam that disintergrates and peels away from the tape.
Post Thu May 15, 2014 10:13 pm
Try using 3M tape.
jotz
Post Sat May 17, 2014 2:27 pm
As Mr Moooore said Shak
Make sure both surfaces are really clean. No dust, polish, silicone.
Always found 4 strips vertically ( 1 inch each) should do the job. 3m is fine green stuff.no need to get complicated.
Clean with methalated spirits first.... and if that dont work at least you can drink the rest of the bottle whilst you whack a few 4'Nails in!!!
SHAKEELE30
Boost Junkie
Post Wed May 21, 2014 8:26 am
you back then jotz?
Ianb
Post Wed May 21, 2014 10:12 am
One thing nobodys mentioned is temperature. I have found that the doublesided tabs work much better if thet are applied when the surface ( and air temp ) is warm.
SHAKEELE30
Boost Junkie
Post Wed May 21, 2014 12:23 pm
does anybody where I can go and buy some 3m foam tape, ive been to whsmith but they only do a very thin one... any specialist shops etc that I can go in a purchase not online...
Gert_8
Post Wed May 21, 2014 12:49 pm
What you need is a product called "Tissue Tape". This is a very thin double sided tape ideal for your needs. Check it out on the following website: www.ukpos.com
10mm roll or 20mm options.
G-Bear
Post Wed May 21, 2014 2:18 pm
Agh feels good to be back on here. Have been busy getting married. But now life (hopefully) restores back to normal; working on my touring.
Have a look on here. Never bought double sided tape off them but their gaffer tape is good.
http://www.gaffatape.com/Double-sided-t ... fault.aspx
Gert_8
Post Wed May 21, 2014 2:40 pm
Congratulations, G-bear! :D good to have you back.
jotz
Post Wed May 21, 2014 2:42 pm
winterbourne road , Thornton heath. Capital car colours
G-Bear
Post Wed May 21, 2014 3:07 pm
Gert_8 wrote:Congratulations, G-bear! :D good to have you back.
Thanks Gertman :D. Enjoying catching up with it all.
Gert_8
Post Wed May 21, 2014 3:10 pm
The interesting threads are the ones with Pony and Rossy in them.. :D
G-Bear
Post Wed May 21, 2014 3:20 pm
Note taken.... E30Enders?
