obc/heater fascia querie?
telski789
Post Wed Jan 18, 2006 9:47 am
hi,does the 13 button obc need a heater panel/fascia with a bigger hole? or is it the same size as the standard clock? cheers
Tel
Simon
Post Wed Jan 18, 2006 9:54 am
Same size as the standard, you just need to unscrew the holder that holds the clock in place.
Cloggy Saint
The standard clock uses a 'frame' that's fitted on the inside of the fascia to make the obc hole smaller. This just pulls out to make way for the 13 button unit.
Same size.
telski789
Post Wed Jan 18, 2006 10:03 am
excellent,cheers boys!
Tel
