6 speed box
jimbom30cab
Tech 1 freak
Post Thu May 08, 2014 10:08 pm
I have seen a 1998 m3 6 speed gearbox which is for sale
Quite fancy getting it, ismit a straight fit onto the m52
I guess I need the prop also to make up a hybrid prop
Could I keep my existing fly, clutch and starter?
jimbom30cab
Tech 1 freak
Post Thu May 08, 2014 10:56 pm
This is the one
Ebay
161294498001
leeparkes
Post Thu May 08, 2014 11:27 pm
Check Dans thread Jim, im sure his 6 speed is from an E46 diesel.
Internet folk law says those M3 6 speeds are weak.
Jibberingloon
Post Fri May 09, 2014 1:00 pm
Chocolate Tea Pot.......
Or made of Cheese
Cant remember which
Post Fri May 09, 2014 1:21 pm
You will need a custom made prop and box mount, but everything else will work, your M20 clutch/fly setup will be fine, but be aware lots of these are shagged old shite now
TSM3
Post Fri May 09, 2014 1:27 pm
Sorry to hijack the thread but I'm also thinking of getting a more modern gearbox to go with my M52.
Was just going to get a standard 5 speed from an e36 328i.
But would these also be shagged and not worth it? What's the alternatives?
Post Fri May 09, 2014 1:32 pm
They are stronger than the 6 speed getrags but yes there is also a lot of scrap about :)
ejoeyward
Post Fri May 09, 2014 2:00 pm
if i was you id get one with a crate of beer and padlock. lock your self in your shed for a week end and rebuild it or just clean it and do a really through service on it and check for metal fragments
jimbom30cab
Tech 1 freak
Post Fri May 09, 2014 2:16 pm
Thanks for the advice guys
Post Fri May 09, 2014 4:11 pm
the 6 speed box isn't as bad as people make out theres some internet hype going on! The e46 6 speed box is the same fit i believe but much nice shift action almost identical ratios
Post Fri May 09, 2014 8:17 pm
E46 is a different spline on the input
Post Sat May 10, 2014 7:52 am
There will be a flywheel clutch setup to suit though i bet?
jimbom30cab
Tech 1 freak
Post Sat May 10, 2014 10:53 pm
right I got a 6 speed set up sorted and a e36 328 auto prop to go on it
will get it all fitted next week along with the M3 E30 3.25 LSD and report back chaps
thanks
Post Sun May 11, 2014 8:17 pm
does the auto prop just bolt on?!
MY question would be will it bolt to an M20 all ok? i guess it would
jimbom30cab
Tech 1 freak
Post Sun May 11, 2014 8:19 pm
dunno mate, will find out this week, it's the stubbiest one i know of so if not i guess it will need a custom prop.
jimbom30cab
Tech 1 freak
Post Sun May 11, 2014 8:26 pm
sorry Si, i missed the bit about the M20 - I wouldn't have a clue mate if all this would fit an M20 to be honest.
Post Sun May 11, 2014 10:09 pm
It will bolt onto an M20 but at the wrong angle, will involve bending/twisting/abusing the shifter linkages and bodging up a new mount, be careful with the auto prop Jim I seem to remember them being too short for proper engagement on the centre prop joint
heathy325
Post Sun May 11, 2014 10:14 pm
Just to jump in what is the best box to use with the m52 set up I'm running the standard 260 box but it is noisey as always and want to get a better one in but don't know which one?
jimbom30cab
Tech 1 freak
Post Sun May 11, 2014 10:19 pm
thanks Dan, if it's too short i'll try a e36 328i manual prop, should be a bit longer
Post Sun May 11, 2014 10:25 pm
The 328i box is best, much stronger than any getrag.
The manual prop is too long Jim
heathy325
Post Sun May 11, 2014 10:34 pm
If you use the 328i box what prop do you use then, will the m20 325i one be ok
Post Sun May 11, 2014 11:29 pm
328i with an E30 centre bearing/mount
heathy325
Post Mon May 12, 2014 11:52 am
But is it the auto prop from the m52 then as you say the manual one is too long dan?
jimbom30cab
Tech 1 freak
Post Mon May 12, 2014 11:53 pm
mmmmmm
so it sounds like the 328i auto prop is too short and the manual too long.
I guess this means get a manual prop and have it shortened and balanced then ??
appletree
Post Tue May 13, 2014 6:00 am
I had a e36 m3 flange welded on a spare IS prop I had and the job lot balanced and powder coated at Bailey Morris cost about £85 iirc and has been very good I just did them a drawing with all the measurements on.
The guy even took me for a tourvof the workshops as I said I was interested in engineering and how they balanced the shafts, they had some huge props in there off earth movers, must have been 8" dia easy.
http://www.baileymorris.co.uk/
heathy325
Post Tue May 13, 2014 8:43 am
So what have people been using then when fitting the 328i box there has to be a way of a home mechanic to get a prop to fit??
Motorhole
Post Tue May 13, 2014 9:06 am
If using the 328i box, the manual e36 328i prop fits just fine with the E30 centre bearing - as DanThe has said. I've done this myself with no issues at all.
You'll find that the centre bearing sits the opposite side of the join in the propshaft and therefore has to be fitted the 'wrong' way round. It sounds confusing, but when you line it all up, it makes sense.
heathy325
Post Tue May 13, 2014 11:38 am
Makes sense now cheers it got a bit confusing then :D
Post Tue May 13, 2014 12:54 pm
The 6 speed box's are longer, so need a shorter prop than the 5 speed
jimbom30cab
Tech 1 freak
Post Tue May 13, 2014 10:29 pm
Hope this will resolve the great prop shaft debate.
So the m52 with the e30 m3 prop fits perfectly, nice and tight
The e36 m3 3.2 6 speed box is exactly 7cm longer
Here are the measurements
Length of e30 m3 prop is 146cm flange to flange
Length of e36 328i auto prop is 128.5cm flange to flange
So basically the 328i auto prop is too short, even extended fully it was too short, like Dan said
Interesting the e36 m3 3.2 prop is 131cm , again too short and of course has the wrong flange on the diff
So basically we need a 139cm prop (maximum) in lengh, lets say 138cm to give us a fighting chance of fitting it easy.
So the only answer is a custom prop
Hope that helps
Anyone recommend a good place I can get my e30 m3 prop shortened and balanced?
jimbom30cab
Tech 1 freak
Post Tue May 13, 2014 10:31 pm
For completeness, Dan has previously said the e36 328i 5 speed manual prop is too long
Post Tue May 13, 2014 11:03 pm
Jim, you would be better off selling the M3 prop, as it will pay for the shortening of a standard prop :wink:
jimbom30cab
Tech 1 freak
Post Tue May 13, 2014 11:05 pm
ok but what standard prop would I need mate?
jimbom30cab
Tech 1 freak
Post Tue May 13, 2014 11:08 pm
e36 328i auto prop on the right
e36 M3 3.2 prop on the left
Post Wed May 14, 2014 12:05 am
You are better off getting an E30 prop front half shortened and an E36 large flange welded on the front end of it
