How do I remove my back bumper?
Stevieabz
Have a 325i Sport 1987. The back bumper is all wonky and pushed forwards on both sides, I would like to remove it and either correct it or buy a new one. Only thing is, I haven't got a clue how to get it off! Help me please
jonny323i
Is it plastic or metal?
Touring for life
BenHar
Four bolts behind the rear valence and 1 in each wheel arch.
Ben
Ben
Stevieabz
Thanks ben, will check it out when I get time, and some sun!
Stevieabz
I've seen so many answers now, I'm still confused. A lot of people are saying.. good luck, get a professional body worker to do it as it involves re-welding.. Some say bolts some say from the inside. But my main concern is that a lot of these e30 have different bumpers on and I'm really not sure what type I have.
BenHar
My experience is with convertibles.diable wrote:From inside of the boot I believe.BenHar wrote:Four bolts behind the rear valence and 1 in each wheel arch.
Ben
I believe that tin tops have three of the bolts for the rear mountings under the valence and one in the boot.
Ben
jonny323i
Thee is only 2 types preface lift or facelift
Metal or plastic.
You have the metal it's been a long time since I removed one.
There are 2 brackets that are bolted through the body with 2 bolts each and the ends of the bumper rubbers are bolted through the rear arch.
Maybe this will help
Metal or plastic.
Touring for life
Stevieabz
Thanks guys you've all really helped!
jonny323i
Either that or tie it to a very big tree and drive away at speed
Touring for life
Stevieabz
I think that would end in tears!jonny323i wrote:Either that or tie it to a very big tree and drive away at speed
