Is there a way to bypass the oil sender level sensor?
I want to establish whether the sensor is faulty or whether I have a wiring loom issue?
I've tried cleaning the sensor but had no luck.
I believe there are 3 points within the connector?
Its for a m20.
Oil sender level bypass
gaszman
- E30 Zone Meets/Events Team
undo the two nuts that hold it in place unclip the wireing plug and then when drained of oil turn it upside down should here a clunk if not soak in petrol over night then try again . they clog uop big time and are an easy thing to fix .
if not i have a cleaned one here
SilverShadow
- Hartge Crew
Thanks for the reply.
I had cleaned the sensor thoroughly in petrol before I installed it, thus asking the question regarding the bypass.
any ideas?
any ideas?
