Few faults with 325i sport I've just bought.
Josepi
Post Thu May 08, 2014 9:43 pm
Hi, just purchased a tech 2 sport after wanting one for years but has a few problems and could do with a bit of help in sortin them.
First off the passenger side footwell is wet, checked the drain from sunroof to a pillar and from there too the underside of the car and the water is flowing through...any other ideas?
Also the wiper motor is mega slow and doesn't work on intermittent.
Lastly the rev counter and mpg doesn't work? And that half of the dash wasn't lit up on the drive home but has come on now. Is this a clocks out job or is there other easier faults I can check first
Nice on for any advice, have looked around the forum but nothing is any clearer... :mad:
Josepi
Post Thu May 08, 2014 9:47 pm
Anyone know of the car I bought actually... H368 AFV. Good or bad
polsta
Post Thu May 08, 2014 9:48 pm
Wiper motor common fault look on the wiki - remove open and clean and grease it should see it right or if you find its knackered and rusted in there replace it
Dash lights are just bulbs need replacing , there are various bulbs all over it look in the wiki for thy type and locations and guides to replace its not too hard
sweep
Post Thu May 08, 2014 9:51 pm
Check the heater control valve its under the dashboard on the passenger side just at the side of the heater box/or for corrosion at rear of glove box?
Wiper motor wants removing and all the old grease removing and fresh grease putting back in or buy a good used one!?
Sounds like si board in your cluster is faulty
Josepi
Post Thu May 08, 2014 10:03 pm
Can you get hold of new si boards or can you repair them?
gaszman
Post Thu May 08, 2014 10:05 pm
yes i have one for a tenna plus postage working
my pay pal is davidfinalact@aol.com 15 pound all in
dont forget your address pm me with that
Jookeone
Post Thu May 08, 2014 10:10 pm
My damp footwell turned out to be water trickling through the grommets where the aircon pipes enter the car through the bulkhead. The solution for me was to prevent water from getting into the area within the engine bay where these pipes sit.
It turned out to be water dripping down through a join in the bodywork beneath the rubber seal that sits along the upper edge of the bulkhead to seal against the bonnet. A careful bit of sealant placed here prevented the issue.
I lifted the carpet and left a dehumidifier going for a couple of days to dry it all out properly. Now after a few months the carpet has remained completely dry (until next time...)
I spent quite a while trying to find the route of this leak. Had checked all of the common causes I found online to no avail and even had the windscreen out fearing the worst.
Good Luck!
Jack
Josepi
Post Thu May 08, 2014 10:26 pm
Ill check that area out jookeone, seems like every car I buy has interior leaks! Nightmare!
Will pm you now gazsman. Nice one
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri May 09, 2014 6:29 am
Sounds like your car has the usual issues common with tired old Sports (and every other E30 :D ). Fortunately the Wiki covers most of it. Click the blue links for more info on a specific part.
Wet Footwell:
http://www.e30zone.net/e30zonewiki/inde ... t_Footwell
Wipers:
http://www.e30zone.net/e30zonewiki/inde ... per_faults
Non-working gauges:
http://www.e30zone.net/e30zonewiki/inde ... n_Problems
Getting your dash cluster out:
http://www.e30zone.net/e30zonewiki/inde ... eplacement
Josepi
Post Fri May 09, 2014 1:16 pm
Spot on
Post Fri May 09, 2014 1:36 pm
Non-lighting instruments may be because you have inadvertently dimmed them; the headlights switch also doubles up as the instruments lamp dimmer - rotate it to adjust the brightness. :wink:
