Newly fitted Limited Slip Differential
pony
- I have been misbehaving and am sorry !
Hi I have just had new LSD fitted (fully rebuilt by Gareth, 40% lock up, 3.91) to my E30 325i Sport (1987).
I previously had an open diff and have had some sideways moments in that.
I haven't driven this E30 for about 2 years.
Are there any special running in procedures ?
What can I expect in terms of handling differences ?
Will it drift and go sideways much more easily now ?
Will it be easier or harder or the same to control when going sideways ?
ross_jsy
It will understeer more however oversteer is easier to provoke and control.
To be honest there are far better upgrades you could have made for the cost of a modded diff, unless it's being used on track I can't see the point
pony
I am using it as a daily and hopefully touch wood DWYB days once per month.
Looking back I was thinking maybe a Kaaz 2-way LSD or Quaife LSD as other alternatives but in the end chose this option as was certainly a lot cheaper than a New Quaife LSD and was closer to retaining a philosophy of using Genuine BMW parts as much as possible.
ross_jsy
I've heard that's why you aren't his favourite any moremaxfield wrote:I nice tight rear end is a good upgrade if you ask me Rossask pacer.
You don't need to run it in.
Will definitely improve handling/grip and be more controllable sideways.
pony
So is anyone here going to give specific advice on breaking in LSDs or what ????
I saw a site which says do figures of 8s for 30 minutes and accelerate at 20km/h in the straight in each gear
How the hell am I supposed to do that ????
pony
Instructions here what do u guys think ?
http://www.driftworks.com/forum/technic ... w-lsd.html
Gert_8
That's bollocks. Did the manual say to do this on a new car with an LSD factory fitted?....use your sense.pony wrote:So is anyone here going to give specific advice on breaking in LSDs or what ????
Gert_8
Sorry. Let me rephrase that last statement.
I do not believe the user manual supplied with an original sport fitted with an LSD, from the factory, advised you should do figures of 8 for 30 minutes and then accelerate at 20km/h in the strainght in each gear..... that's just stupid.
Gert_8
Yep, I still think it's pointless.
Gert_8
If you want to make it last as long as possible, may I suggest you don't go drifting then?
No, it's not extreme enough to need a specific running in procedure.pony wrote:All I want to do is make it last as long as possible so if I have to follow a running in procedure I will do and vice versa
Cost a small fortune and for me is the best part of it
You don't need to do anything special, but like any recently changed mechanical component it's a good idea to do a few 'normal' miles and gradually build up loads / temperatures rather than bolting it on and going straight out for a half hour drift session.
But I think that's just my preference for a bit of mechanical sympathy, and probably isn't necessary.
Changing the oil after the first 1000 miles or so after a rebuild isn't a bad idea either, although again, with modern materials and oils probably isn't really necessary.
cheers,
harry
harry
magpie wrote:i'd be looking at the rear beam bushes before you start diffin .
It's all new, she's fully motorsported up with lots of new poly bitz. He's off to Wales on the weekend for a BMWCC sausage fest so the sheep better be on their guard, an out of control Tech 1 has got to hurt more than a boyos knob
Gert_8
Here it is to save you searchingross_jsy wrote:Let's just read Gerts sig to remind ourselves of Pony's drifting skillz
I've done about 10-15 sedate miles in it since fitted, its ready to go side ways now!
gareth
Just get in and put a few miles on it before going silly. drop the oil after a few K and throw new stuff in and it'll be fine.
The last diff I shipped out got bolted up the arse on a full race E36 M3 Evo, driven across a car park, onto a trailer, towed to the 'ring, straight out on track and started qualifying! The following day it came second in class at a 4 hr VLN endurance race! No bed in whatsoever
Oil came oit clean as a whistle post race
At the end of the day, it's a bunch of metal bits sliding around other metal bits. Use some mechanical sympathy for a while as parts bed in together, followed by an oil change to clean out the deposits from this bedding in period.
