S14 coolant leak .. feeck sake
johnono
Post Sun Apr 27, 2014 8:38 pm
Heya :)
so after the engine has idled for about 3-5 minutes there´s a fairly noticable dripping , off the engine carrier.
The hosing to the expansion bottle / thermostat / cooler are dry
The hosing to the matrix is dry
Im thinking ít must be off the coolant pipe along the head ?
the one you can just see between the strut tower and coil
After 10 minutes the leaking stops.
And doesnt come back even after driving for over an hour.
But if it alowed to cool to cold, then the leaking begins again on start up after 3-5 minutes..
No abnormal pressure in expansion bottle
oil and water look fine
ffs :)
Post Sun Apr 27, 2014 8:58 pm
Radiator tank seals can leak and then 'heal' when warmed up. As can the waterpump . Both parts are M3 specific and expensive :(
johnono
Post Sun Apr 27, 2014 9:30 pm
cheers Pete :)
yeps, but you have to pay to play :(
