fuel pump relay
321gazza
Post Fri Apr 18, 2014 12:18 pm
Can anyone tell me were the fuel pump relay is for my 318i h reg saloon and the colour, think its orange in colour and is a bosch relay thats just a simple on/off relay or is it a white one. The orange relay has the fuel pump coloured wire coming out of it, purple/green but need to make sure.
sanitroc1
Post Fri Apr 18, 2014 5:16 pm
Yes orange one on the bulkhead under the plastic cover , mine failed on Monday so been there done that .
321gazza
Post Fri Apr 18, 2014 8:21 pm
Thanks very much, what is the one next to it as it seems to have a red and white wire connected to them both.
321gazza
Post Fri Apr 18, 2014 9:33 pm
Main relay is that the ignition relay or what does it do.
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Apr 18, 2014 9:53 pm
Post Fri Apr 18, 2014 10:21 pm
When you switch on the ignition switch a signal is fed to a section of the engine ECU that tells it to switch on the DME (main) relay. This relay supplies power to the injectors, to the fuel pump relay (but does not turn it on), to the rest of the ECU, and, on later cars, to the ABS system if fitted.
The fuel pump relay is turned on by the ECU when it detects pulses coming from the crank position sensor.
There is also a relay socket adjacent to these two, for the heater of a lambda sensor. Most UK cars aren't fitted with emissions equipment, so this socket is usually empty.
321gazza
Post Fri Apr 18, 2014 10:28 pm
Thanks that is perfect.
