2006 320i M-sport value
Theo
145k miles, no tax/test, needs a new alloy and rear wheel bearing.
Thoughts on value?
Thoughts on value?
2k ish sounds about right. It will cost at least another £500 by the time it has some rent on it. Then you need to pray that the chocolate engine does not poo itself
I am guessing it might make 3.5 ish done and tested.
Theo
Thanks Pete, it's a quattroporte. Does that make a big difference?
I guessed as much
Coupe is obviously much more saleable, M Sport innit
Even as a quattroporte, it is still a saleable turd, new shape M Sport innit
Theo
F*cking executive!
Is doing the wheel bearing is a simple enough job on these turds?
Andyboy
- Alpina Colada
Not bad if you have the suitable pullers. These shitheaps love a rusted/broken ABS ring so it makes sense to fit a new one with the shaft out. They're about a tenner each and easy to fit.
Horrible N46 engine with the the attendant dramas.
Theo
Thanks Andy, what are the attendant dramas you speak of?
Pull up a chair , a cup of coffee and Google BMW N46 problems
On a positive note,at 145k , most of the issues should have been fixed, several times
darkchild
I had a N42 powered turd. The only car I've ever had where the dipstick rusted. Bought a replacement and that rusted as well. Horrid engines
Oh, and oil leaks...and coil packs...and everything takes hours to fix. A true legacy of BMW's time with Rover.
I should be grateful though. No timing chain tensioner issues when I owned it.
N42/N46.
BMW's worst engine ever!
Theo
Sounds like these are real shit heaps
Theo wrote:Sounds like these are real shit heaps
Is it much cheapness ?
Andyboy
- Alpina Colada
If it's 2 grand or so then you can invest £5-600 on a new chain/tensioner, fix the oil leaks and replace the TDC sensor. With luck it should be okay but you still have the VVT motor, eccentric shaft wear and that sort of nonsense. I wouldn't give one garage space myself.
But if you can turn an eric on it.......
Eccentric shaft wear problem was sorted by then.
The E9x 3 series is a good car on the whole, but yours is saddled with THAT engine.
What's happening with the Hartge?!
Theo
It is cheap, its one of our company cars which we're getting rid of. Its not had a nice life
Nothing is happening with Hettie, I want someone to do the work for me as I don't have the time.
mcbonio
Andyboy - the OPs car is a 320i which is M54B22 engine not a N42.
I'd say car was worth 2 - 2.5k depending on spec and condition.
Theo
It's a 4 pot banger so not an m54
It's an E90.mcbonio wrote:Andyboy - the OPs car is a 320i which is M54B22 engine not a N42.
Theo is not stupid, he would not waste his time foook1ng about with old worthless E46 council frag !
mcbonio
The first post doesn't say it's an e90, just that's its 2006. E46 ran until May 2006 also. My confusion is valid!
But we had already established MUCH earlier in the thread that it was an E90 with the nasty N46 engine .
The E46 saloon was replaced in late 2005 by the E90 but E46 convertibles and coupes soldiered on for another year
pony
- I have been misbehaving and am sorry !
E90 saloon came out in 2005 plates
E46 3 Series Coupe built until May 2006
E46 3 Series Convertible built until August 2006
