snapped bleed nipple rear caliper
chinna
what are my chances of drilling out the rest of my bleed nipple? snapped flush with the caliper after a week of wd40
maxfield
Depends how competent you are with a drill.
chinna
got a cordless dewalt of used in the past to drill out a caliper bolt that held it to the leg? got a major mains powered drill also. cant believe this happened now. rebuilding the whole rear end this weekend as i need to move my car. gettin new brake pipes and flexis friday. the others came undone no problem, this one just twisted and snapped.
Grrrmachine
- E30 Zone Wiki / Team Member
Get a Torx bit and hammer it into the hole, then gently twist the broken nipple out.
chinna
will giv it a try. not sure if i've got a bit that small, but
BenHar
If you do have to drill it, try a left handed drill bit.
Ben
Ben
If the priority is to move the car, you can bleed it by loosening the hose at the join with the caliper.
Caliper needs to be off, the piston clamped back as far as it will go, and the join uppermost.
If it comes to a replacement caliper, don't forget that touring ones use a different sized piston from the others.
Gavt
Easy outs work every time I've done loads it's fits and grips perfectly and there's plenty of spare nipples in the scrappy
Next post: How do I remove a broken easy out from my broken bleed nipple?
- E30 Zone Meets/Events Team
LMFAOwillnz wrote:Brianmoooore wrote:Next post: How do I remove a broken easy out from my broken bleed nipple?
