s50 idle rough
hi all,i will try and describe this as best i can,
ive just completed my s50b32 e30 and it ran perfect until i took it for first long drive,it runs fine when driving it,pulls strong and doesn't miss but when its at idle its got a bit of a miss/surge which makes the car rock a little,the rev needle sits in the right place and doesn't seem to surge with it.
its had a new fuel filter,
ive checked all vacuum pipes and renewed any cracked ones including the little tee piece cap,
ive run some injector cleaner through it,
plugs all look fine but ive ordered new anyway,
ive cleaned the maf,
ive unplugged the throttle position sensor when running and it doesn't alter the sound,
ive also cleand the idle control valve,
would plugging it in show any faults ?
any help please!!
any help please!!
yes dan,ive checked all i could find and they all seem ok but i will have another go at them,really annoying as it runs perfect when driving it and just idles rough,i thought it might have been oil on the air flow meter from the k&n filter because it only started doing it after its first long drive but ive had that out and cleaned it with carb cleaner and its no different
you're ews delete worked perfecly by the way,ive got it booked in on Wednesday with a guy who looks after my brothers cosworth who is good at fault finding so lets hope he can tell me what it is causing the rough idle
e30rapidic
O2 sensor?
runs same with no 02 sensors not plugged in,
ive got the e36 m3 evo pump in e30 hanger ,is there any way in which it could be a fuel pump faulty ,[bought second hand],it also seems to have slight hesitation from idle to 2000rpm
- Mikey_Boy
Just a thought - if it runs the same without the O2 sensor connected, I would suggest that might be your fault right there. The O2 sensor 'trims' the air fuel mix from the map to get the lambda reading spot on - if that isn't working it will idle rough and run ok through the rest of the RPM range (at part load it trims until fuel is needed for cooling but you either won't notice its effect or it might feel like a hesitation) and at full load the O2 sensor usually does very little.
Hope that helps...!
Hope that helps...!
- Mikey_Boy
And just for reference fuel is needed for cooling above 3000rpm normally, so from what you describe, I would try O2 sensor next... It's effect is most pronounced at idle condition.
Demlotcrew
Have you had a vanos test carried out?
