Removed with manifold in place.
Partly followed the wiki article here:
http://www.e30zone.net/e30zonewiki/inde ... _injectors
But found that I had an older type of electrical connector. At first I couldn't work out how to remove them but found that they popped off easily enough with a big screw driver.
Next change from the wiki procedure was to remove the clips that hold the fuel rail to the injectors and take the rail off leaving the injectors in the manifold. This made it much easier to get the rail out.
Then wiggled the injectors out of the manifold individually.
When reassembing I also put the injectors in individually then fitted the fuel rail. Getting the rail in with the injectors attached is very tricky and I was worried about bashing the newly refurbed tips.
There are four bolts holding the rail in, not three.
Ben
