M3 touring car suspension setup
ben-yatess
Post Fri Apr 04, 2014 7:24 am
Hi i was watching a programe on touring car legends the other night, and the e30 m3 made quite the apperance, i noticed that they handled amazing, just wondering if anyone knows the correct suspension setups that some of them ran like:
wishbones
struts
springs
dampers
allignment
that sort of thing
cheers
maxfield
Post Fri Apr 04, 2014 8:02 am
A quick google search of 'E30 M3 DTM suspension' will give you a good idea.
I imagine springs/dampers/alignment was different for every track too.
jmc330i
Post Fri Apr 04, 2014 8:43 am
James
'91 325i Sport
'93 318i touring 16v
ben-yatess
Post Fri Apr 04, 2014 9:16 am
maxfield wrote:A quick google search of 'E30 M3 DTM suspension' will give you a good idea.
Yeah i agree but it will all be with in a range i would have thought?
89pgy
Post Thu Apr 10, 2014 9:34 pm
to be honest its way out of most peoples range,
used blade anti roll bars £3k
uniball front wishbone set up £2.5k
front legs for centre lock rims £3k and these will not come with shocks /springs/ lower hubs/bearing
rear trailing arm £2.5k
all rubber bushes removed replace with ali so unless you have a seam welded shell with a welded multi point cage a std car will be cracked in no time.
