I no lots of you probably don't enjoy this topic but I baught apparent custom coilovers from gaz took them about a month to do and yet the camber all seams to be odd has anyone used them before and had problems?
Cheers guys!!
Gaz coilovers
j4gz
Hi I also got some issues with mine I got spacing issues how is your setup with regards to spacing ? Do you have to use any spacers on the fronts or backs ?
Tonyy93
Yes! Iv got if I remember 20mm spacers on the front and had to go for quite stretched tyres to stop rubbing badly but even with the spacers and 195 50 15 on original wheels it's still not that good!!
I have no problems with 15 inch BBS and 205/50 tyres
Tonyy93
Dan what coil overs are they gaz golds? Or the cheaper ones?
gooseygander110
Me neither on Gaz GoldsDanThe wrote:I have no problems with 15 inch BBS and 205/50 tyres
Yep, Gaz Golds
MattT
I have Gaz coilovers. I run 20mm spacers on the front and none on the rear with 15" BBS and 205 tyres. Arch lips are pushed back abit but it doesnt rub. It does have a fair bit of neg camber though at the front, I`m not to bothered as its a track car.
ross2009
ive got full coilovers all round and dont have a prob and im running 9j all round spacers only on front
