Whas this Pannel called?
beemerstu84
Alright,
Need a bit of help here, any 1 no what this pannel is called? & has any1 got 1? http://i36.photobucket.com/albums/e21/i ... pannel.jpg
Stu
Stu
kam-325i
Thats part of the front valance.....
E30Mark
It's part of the front valence, you have to change the complete item behind and below the front bumper.
PM for details
PM for details
stevetigger
You can just grind this bit off! And weld a new one on! I know, I had to do it in an old Sport of mine.....When an old lady hit it!
kam-325i
Its easier to replace the whole front valance.......stevetigger wrote:You can just grind this bit off! And weld a new one on! I know, I had to do it in an old Sport of mine.....When an old lady hit it!
E30Mark
damn site easier to replace the whole front valence as it just bolts on...
PM for details
PM for details
stevetigger
I know but I was doing other stuff tookam-325i wrote:Its easier to replace the whole front valance.......stevetigger wrote:You can just grind this bit off! And weld a new one on! I know, I had to do it in an old Sport of mine.....When an old lady hit it!
slam panel is the panel above the lights steve.
Not sure what that one below the lights is actually called though
stevetigger
on etk it just says.....Front Panel
E30Mark
Thats for a pre-facelift model, the realoem is wrong!E30BeemerLad wrote:http://www.realoem.com/bmw/showparts.do ... g=41&fg=10
PM for details
PM for details
stevetigger
Thats the same as my etk!E30Mark wrote:Thats for a pre-facelift model, the realoem is wrong!E30BeemerLad wrote:http://www.realoem.com/bmw/showparts.do ... g=41&fg=10
that's wierd as I used my vehicle age/ build date etc, mine being Oct 87 build and a facelift car
stevetigger
i used etk with my chassis number being a 1993 car and thats what came up!
kam-325i
Strange, when i had to replace that part(the bit under the lights), i could not get it, so i replaced the whole front valance, and it was a lot easier aswell....
JOSEMI
is this a bolt-on only part ? just curiosity, I have to fix mine too...kam-325i wrote:Strange, when i had to replace that part(the bit under the lights), i could not get it, so i replaced the whole front valance, and it was a lot easier aswell....
Jose
E30Mark
Look at the picture on the realoem/etk, it is the same picture. But neither have cut-outs for the brake cooling ducts, plus it shows the cut-outs for the towing hooks which the face-lift cars don't have. The ETK is Wrong wrong wrong !
Please don't make me go out to the garage and drag out and photograph my spare front valence...
PM for details
PM for details
kam-325i
The whole front valance is a bolt on part, but the small lip bit that shows below the lights is not bolted to the original valance, its part of the pressing. It took me about 1 hour to remove the old damaged one and refitt the new one.JOSEMI wrote:is this a bolt-on only part ? just curiosity, I have to fix mine too...kam-325i wrote:Strange, when i had to replace that part(the bit under the lights), i could not get it, so i replaced the whole front valance, and it was a lot easier aswell....
Jose
JOSEMI
thought so, it looks been welded on the sides, cheers fella !!
Jose
Jose
Martinaston
On the pre-facelift its just a strip thats bonded at the ends and bolted from behid, on the post facelift it's the whole front vallance (Ԛ£50 ECP)
There is NO nucleus.
Bob_S
or if you have a good local scrap yard Ԛ£10 and if your fortunate it will be in the right colour
Bollocks to this 24v scrap!
