Time-sert size time!!!
rich318i
Post Thu Mar 20, 2014 9:09 pm
Right not messing about now.
what size serts has everyone used with their M52/M54
M10x1.50x ???
No silly comments please about the race team and that TA
leeparkes
Post Thu Mar 20, 2014 10:26 pm
Serts?
leeparkes
Post Thu Mar 20, 2014 10:28 pm
Ah now i see...
http://www.timesert.com/
You not using an iron block?
rich318i
Post Thu Mar 20, 2014 11:00 pm
na fella m52 not a M20/M50 family
Jimbob
Post Fri Mar 21, 2014 8:49 pm
Say what. If you're sure the block has never been subject to overheating then give it a try without the timeserts surely?
rich318i
Post Fri Mar 21, 2014 8:51 pm
Jimbob wrote:Say what. If you're sure the block has never been subject to overheating then give it a try without the timeserts surely?
I am.. just thinking ahead fella
Post Sat Mar 22, 2014 12:00 pm
I used M16 because they are stronger innit
rich318i
Post Sat Mar 22, 2014 8:43 pm
20mm, 24.5mm or 30mm in length??
maxfield
Post Sat Mar 22, 2014 11:48 pm
Surely whoever is building your engine should be the ones sorting timeserts. They're the ones who have the engine in bits and can measure the threads etc. And also telling you if you even need them
rich318i
Post Sun Mar 23, 2014 9:57 pm
maxfield wrote:Surely whoever is building your engine should be the ones sorting timeserts. They're the ones who have the engine in bits and can measure the threads etc. And also telling you if you even need them
well as i said before just thinking ahead and like to know what sizes others have used in the past. Block is a non over heated job
